(#151)
joselarajan87's Avatar
joselarajan87 joselarajan87 is offline
Banned
Car: 2009 Bmw 335i
Default 01-12-2017, 11:35 AM
Originally Posted by Marcos_Nunes
Do i Have to uninstall MHD to do the flash?
no you dont
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-12-2017, 11:50 AM
No, have nothing to do with MHD , TCU flash totally different than ECU
09 E92 335i - GULF Version, Hot-Climate Version, Middle East package, M Sports suspension, 19" Rims, 6AT with Xhp stage 2 flash, JB4 - Map 3 - MHD BMS Race Flash with modified Duty Bais and PID - BMS Oil Cooler Valve - RB PCV - K&N drop in Filter - AFE Air Scoops - 98 Super Fuel - WAGNER FMIC - 3" **'s - BMS Water/Meth 40/60 VP Racing M1 with 70 adder
Marcos_Nunes's Avatar
Marcos_Nunes Marcos_Nunes is offline
Car: E92 335i
Default 01-12-2017, 11:56 AM
My car is on the limit off the month that is possible to flash the Alpina software.
Can i do it and get it back to stock if it goes bad?
Banned
Car: 2009 Bmw 335i
Default 01-12-2017, 12:04 PM
yes
IssueZ901's Avatar
IssueZ901 IssueZ901 is offline
Car: 2008 135i M Sport
Exclamation Winkfp guru required - 01-15-2017, 08:19 PM
Hello. I live in Australia and have followed this post in to flash to Alpina 7615835. I have since tried another flash (7615835) and was flashing to 7603537 when I had a fail at 1%.
I have been reading everything on the Internet and changing settings etc with no luck. Trebila mentioned to try the virtual box image for programming and still coming up with the same error.
I was wondering if someone could help me with this, I have been at it for 4 days now and just want to drive my car! Any help would be greatly appreciated. I can't do remote access right now as my home Internet is not working. Having said that I could tether off my phone! I really am desperate for a fix here.
I hope someone can help. Pic of the error window attached.Name:  yimg-155440140-9002-1021857415.jpg
2008 135I M-SPORT. AT. ST GTX3076R. JB4/TREBILA BEF. XHP STAGE 3. PUMP98 & 70/30 METH DPI. FOCAL IFBMW-C +IFBMW-S.
gio911gio gio911gio is offline
Car: 07 e90 335i n54
Default 01-17-2017, 12:54 AM
See this helps it help me https://www.youtube.com/shared?ci=PUQVqsjHB98
IssueZ901's Avatar
Default 01-17-2017, 09:14 PM
I followed part 1 and part 2 of tose videos the first time I flashed. I have flashed again after that and failed this time. My egs is stuck in programming mode 12. I can't seem to access it with anything because it can't read the ecu identifier to make sure of a match.
Banned
Car: 2009 Bmw 335i
Default 01-21-2017, 02:01 AM
Originally Posted by Wedge1967
Call me 503 679 3538
we tried flashing different methods... winkfp/nfs/istap/ etc with his k+d can cable all the software keeps failing... we tried disconecting the batt overnight,we hooked up a batt charger etc. nothing worked.. im thuking his k+d can cable might be defective.
Den* Den* is offline
Car: BMW e92
Default 05-13-2017, 02:12 AM
hello guys, i have following errors while loading the flash. it sounds like WinKFP couldnt see TCU, any ideas?
Car: BMW e92
Default 05-15-2017, 06:58 AM
no answer at all ?
Js@eurotuninggroup Js@eurotuninggroup is offline
Banned
Car: ST 335 N54
Default . - 05-15-2017, 07:24 AM
i can help you get it back to normal. pm me
Banned
Car: ST 335 N54
Default 05-15-2017, 07:25 AM
i can help you pm me
Car: BMW e92
Default 05-15-2017, 01:02 PM
Mail sent
madmatt9471 madmatt9471 is offline
Car: 98 Vette 734 whp, 08 335i e90 n54
Default 09-11-2017, 08:31 PM
Subscribed -
Thanks,Matt
Kaz26 Kaz26 is offline
Car: 2008 335i White on Lemon Dakota and Black
Default 02-09-2018, 12:18 PM
This is probably a stupid question, but I just want to be sure. Does the Spdaten file need to simply be newer than 49.3 or does it need to be a specific Spdaten to work?
I believe I am already updated to 60.1 and just want to make sure it will work ok.
Thank you,
Kaz
GEOS07335i GEOS07335i is offline
Car: 2008 BMW 335i E93 N54
Default 02-25-2018, 04:44 PM
I recently purchased a bimmergeeks cable and installed third version of 5.0.6 how can I tell if I have the correct sp Daten files a and as precious poster asked does it matter if I have a newer version
Default 03-09-2018, 01:39 PM
I cant fine the pdf file to import the 53 SPDaten files? Trying to figure out how to update my winkfp app.
Default 03-12-2018, 03:22 PM
Finally figured it all out. Was a bit of a PITA but wow was it worth the effort. I'm really liking it. Thanks to all that contributed to this great mod.
Default 03-12-2018, 04:57 PM
Updating the daten files shouldn't be a PITA at all. Just open "BMW coding tool", select "Update SP-daten", select the daten folder to update to and it does it all for you. That's the best way to do it, super easy.
Default 03-13-2018, 10:08 AM
In the coding tool there is also an option to update Winfpk should I have updated that as well?
Default 03-14-2018, 12:05 AM
I believe so. Atleast I always update WinKFP, but it would be good to know for sure if anyone else knows the answer to this.
Default 03-14-2018, 05:13 AM
I had to do more than just update the date files. I also had to copy three separate folders as well. I saw it on some YouTube video.. I was getting error 211 I believe something about security. But in the end I got it to flash. And it's the best bang for buck mod I've done so far.
Default 03-14-2018, 03:27 PM
Supposedly xHP is significantly better than Alpina. It makes me curious, but I wonder how much of that is marketing hype.
spooled2 spooled2 is offline
Car: BMW E82 135is 2009
Default 05-04-2018, 08:29 PM
I had this flash and it worked fine but every once in a while I would get half engine light and when I checked codes it would show EGS not coded. Should you do coding after the flash in NCS expert or does WINKFP do that for you? I have since flashed back to stock.
bmweurotuning's Avatar
bmweurotuning bmweurotuning is offline
Car: Bmw 335i ST
Default 08-04-2018, 07:56 PM
code egs module to default.... limp mode might be cause by other component.
WEBSITE: http://www.bmweurotuning.org
FACEBOOK GROUP: https://www.facebook.com/groups/657429951109356/
INSTAGRAM : https://www.instagram.com/bmweurotuning
YOUTUBE CHANNEL:https://www.youtube.com/channel/UCQi...u2MWT7P2ZYus5g
http://bmweurotuning.org/store
http://bmweurotuning.org/videos
For more info on jb4 products for your turbocharged bmw click here:
http://www.burgertuning.com/
