(#576)
Aplav1982 Aplav1982 is offline
Car: 2020 Honda Accord 2.0t
Default 05-08-2020, 05:48 PM
So put a 1/4 mile down and ran 14.3. I know i can do much better. Im wanting to get into the 13s. 2020 accord sport 2.0 jb4 stage one prl intake and kn filter
Default 05-08-2020, 08:38 PM
Not bad! Log of the 1/4 mile run?
Originally Posted by 2020xgen
Map 4 on e30. How does it look? My car feels great on this map!!
Looks perfect to me here. Boost and AFR are solid, knock count on the floor.
2020xgen 2020xgen is offline
Car: 2020 Honda Civic si
Default 05-09-2020, 08:25 AM
Thanks! I have to say I am really impressed at the jb4!
Default 05-09-2020, 05:07 PM
Thanks help spread the word on social media to help grow our Honda Turbo JB4 userbase.
Default 05-10-2020, 07:15 AM
Hey how safe is map 7 to run? Thanks!!! I'm currently running maps 4 and 5 on a e85 blend of 30% e85 and the rest 93oct.
Shane060 Shane060 is offline
Car: 2020 Civic Si
Default 05-10-2020, 06:49 PM
Can anyone help me out with the AVG Ignition readout? Not sure if it is supposed to show constantly but for some reason it only worked for my car when I initially installed the JB4 and app. I believe it showed 0.5 but again I am not sure what the reading is supposed to be since it has just been showing 0.0 and nothing more. Everything else is running smoothly so maybe Im just not educated enough on this reading.
Default 05-11-2020, 09:45 AM
If learned knock is at 0.50 (shown under ign 2) then iavg is going to be sitting around 0 also.
Car: 2020 Civic Si
Default 05-11-2020, 05:41 PM
So if looking at avg while driving and it going from 0.0 to like 0.2 and then watching the IGN 2 and seeing 4.8 4.9 pretty solid with the occasional 5.0 at idle would you say everything is looking good? Running shell 93 and a octane booster on map 3 with a injen short ram intake
Default 05-11-2020, 07:01 PM
Yes that is the lowest possible learned knock factor.
Default 05-12-2020, 10:43 AM
Terry is Map 7 safe to run?? It says run at your own risk has there been testing since to show its safe?
Default 05-12-2020, 10:53 AM
More boost, more risks. So I'd keep that one for really aggressive situations like unleaded race gas at the track, etc.
Default 05-12-2020, 10:57 AM
What octane race gas do you recommend for the that map?
Default 05-12-2020, 12:34 PM
100 RM2 unleaded race fuel as a starting point.
Default 05-14-2020, 11:49 AM
Terry is an E85 blend ok to run on map 7 or will that hurt car thanks
Default 05-14-2020, 08:23 PM
The fuel system may not be able to keep up, so you'd have to evaluate it, and monitor fuel pressure, as well as knock. Maybe an E35 mix?
Default 05-18-2020, 12:48 PM
I am adding a mangaflow exhaust to my Accord 2.p
0 will the jb4 automatically adjust for that? Thanks
Default 05-18-2020, 05:13 PM
Yes!
Default 05-22-2020, 05:08 PM
So I got my magnaflow exhaust put on my 2.0 and I was in map 4 running e85 blend. I was in Mexico playing and punched it going about 70 to 100 and it threw me out of the map and put me in limp mode and gave me a 0234 code which is boost pressure was to high. I cleared the code and restarted the car and I put it map 3 and have not had another issue but I haven't pushed yet. Any ideas why that happened?
Default 05-22-2020, 05:40 PM
It's overboosting now
Default 05-23-2020, 10:26 AM
Car: 2020 Civic Si
Default Yesterday, 09:17 AM
Hey Terry I’ve noticed I’m having issues with my Bluetooth adapter connectivity! It will not read codes any more and also will not display other values besides boost as of this morning. I’m not sure what is going on, I’m on the latest firmware and it was fine until this morning.... I’ve only had the unit for about a month or so, any help would be greatly appreciated as I’ve checked all the connections and still no luck.
Default Yesterday, 07:19 PM
Originally Posted by Shane060
Hey Terry Iíve noticed Iím having issues with my Bluetooth adapter connectivity! It will not read codes any more and also will not display other values besides boost as of this morning. Iím not sure what is going on, Iím on the latest firmware and it was fine until this morning.... Iíve only had the unit for about a month or so, any help would be greatly appreciated as Iíve checked all the connections and still no luck.
Sounds like an issue with the OBDII connection then if you only get boost data. Everything else comes via the OBDII cable.
Car: 2020 Civic Si
Default Yesterday, 08:15 PM
I logged out of the app and reloaded it and logged back in and for some reason that took care of evertyhing! No idea why but simply logging out and back in cleared up the bug and now everything is back to normal!
