Boyce Boyce is offline
Car: Polo GT
Default AFR Lean safety on map 4 - 10-06-2021, 02:25 PM
Hi all, finally found an e85 pump near me so I got a mix of 93 and e85 (think around e30) and the car was running great for a while and all the sudden it dropped to map 0. AFR Lean safety :/. what went wrong? How can I fix it? Log is too https://showbox.bio/ https://tutuapp.uno/ https://vidmate.cool/ long to post but I’ll try to get a map 4 log if it’s advised.
Car: Evo VIII
Default 10-06-2021, 04:04 PM
Get a 3rd or 4th gear log from 2k to redline at wide open throttle, in MAP 4, with traction control off for proper review. Thanks!
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 10-10-2021, 04:30 PM
If I was a betting man, you mixed a bit too much E. very common if you don't have a tester or the fuel it sensor. Fuel pump can't keep up with the demand. In addition, Map 4 is pretty heavy on boost, especially without a proper octane boost. I would start with Map2 or Map3 before you try map 4 again and let someone here look at it.
