bombstar's Avatar
bombstar bombstar is offline
Car: 2019 BMW 330i
Exclamation 2019 G20 330i - Map 2 Logs (boost/throttle fluctuating) - 12-04-2021, 03:44 AM
(pardon the new account, don't have the email for my old lurker account)
Howdy y'all,
I'm currently running a 330i on Map 2 with a DP and ~94 octane fuel (AKI). I'm noticing some weird behaviour (from throttle closures?) when running the car in cooler (sub 15C) weather. The behaviour doesn't seem to occur in Map 3 where boost is a lot flatter (far less throttle dips) but trim steps up fairly fast.
I have a log of the Map 2 run. I apologise that its a little junk as I ran it spontaneously after noting the boost swings/throttle closures.
Any help would be appreciated as this foreign territory for me coming from NA BMWs and turbo Audis.
Default 12-08-2021, 10:58 AM
Something isn't right there. Maybe an install issue? Upload pictures of your install so we can check them out.
bombstar's Avatar
Car: 2019 BMW 330i
Default 12-09-2021, 02:09 AM
All of the issues went away for the most part by lowering gain to 10 and/or just running Map 3. But, it is still a little funky.
I'll try to get some photos in the morning. One suspected question is my EWG connection (A friend had the connector/wire melt) as I had an issue shortly after going to V20 where the waste gate was locked open (and the car built 0/negative boost) until I popped the car into neutral and back into drive. After that, the car behaved completely normally.
A Map 3 log is attached to show the difference.
Current:
2019 BMW 330i
2018 Hyundai Kona 1.6T
Former:
2015 Audi A3 Quattro [EQT]
Default 12-09-2021, 11:36 AM
Yeah, post pics....you shouldn't have to drop PID gain to 10 and it still seems a bit wonky. You could also disconnect the EWG connector completely to test.
bombstar's Avatar
Car: 2019 BMW 330i
Unhappy 12-12-2021, 02:44 AM
Sorry for taking a few days, work took most of my time so I elected to drive my other car.
Photos aren't great (May upload them separately and I have a few more) as I took them after work but this is the current state of things. I can take more with things unplugged to show the state of the pins/connectors if you need. I tried to keep the JB4 away from the OEM wiring as it wasn't terribly well done when it was replaced.
Also attached is a Map 0/2 log. The first run is 0, then I drove the car around to relearn Map 2 before doing 2 runs.
Current:
2019 BMW 330i
Former:
Car: Evo VIII
Default 12-13-2021, 03:39 PM
It's getting better as it was REALLY bad. Throttle closure isn't great, but may need some more time for adaptions?
bombstar's Avatar
Car: 2019 BMW 330i
Question 12-13-2021, 10:25 PM
Yeah, I’m not too familiar with JB4 but from a general tuning/automotive standpoint things looked and felt rough. I’m going to keep things weak for now because I’m a little worried about the car. I was quite surprised by how lax my DME is and I can’t imagine it being a replacement DME would make much difference.
Anything else you want to see regarding wiring?
Current:
2019 BMW 330i
Former:
bombstar's Avatar
Car: 2019 BMW 330i
Default Update after time for adaptation + ~10 more runs - 12-24-2021, 11:31 PM
I’ve let it settle in for a while on Map 1, this is about as good as it’s really getting. I’ve attached another log.
Some info:
- Car is running E20
- Oil consumption seems to have spiked no matter the map, safety map included. No smoke or smell though.
- No idle issues or surging.
Current:
2019 BMW 330i
Former:
Default 12-27-2021, 11:58 AM
Not too bad...update to V21 and put all your user adjustment settings back to the default values...then lets see how a log on map 1 looks.
Antec800 Antec800 is offline
Car: 340ix
Default 12-27-2021, 05:58 PM
Mind posting the default values for the g20 @steve. It seems like terrys post on default values seem outdated for gen1 b58
VipinLJ VipinLJ is offline
Default 12-27-2021, 06:22 PM
It's the same as in the link below.
JB4 B48/B58 Firmware, Settings, and Notes - N54Tech.com - International Turbo Racing Discussion
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
bombstar's Avatar
Car: 2019 BMW 330i
Unhappy Update and quite a severe issue. - 01-23-2022, 03:32 AM
Sorry for being gone a hot minute!
Here is a Map 1 log that came out well. The log was done with ~E24 mix as even Map 1 was a no go with anything less than E20. The most success I had was with a Map 6 based on my Map 2 which built timing far more linearly.
However, last night everything came to a head where the car started knocking hard and then the JB4 cut out about 5 minutes after I swapped to Map 8 to try to minimise any further timing drops. Unfortunately, Map 8 showed basically the same pattern of timing drops after changing up a gear; even at partial throttle. I've attached the auto logging from after the first incident. This was also the first time the car threw knock codes. I noticed in the Map 6 log that the boost targets vs what I set didn't seem quite right when compared with any of my previous driving.
At first I thought it was just the mobile connector dropping out and it was unrelated. This was because after the connection dropped and I had to stop the car it was now stuck on 'awaiting handshake' whenever I tried to reconnect. However, I can't get anything from the JB4 wired either. For now I've removed the JB4 and the car stopped having timing drops immediately.
Current:
2019 BMW 330i
Former:
Car: Evo VIII
Default 01-24-2022, 12:48 PM
Logs look good, definitely making more power in map 1.
bombstar's Avatar
Car: 2019 BMW 330i
Default 01-26-2022, 04:56 AM
Cool, glad at least something looks good right now. I’m still wary of the misfires though. It looks to coincide with the trim spikes after shifting gear. I have a few other logs from the Map 6 and 8 after as well.
I’ve managed to get the JB4 going as a test on Map 8. Judging by how I had to try a few times (moving the wiring loom around at the JB4 end after disconnecting the 2 batteries) it looks like the JB4 probably lost power while I was driving.
Current:
2019 BMW 330i
Former:
