S55_M2 S55_M2 is offline
Car: M2 COMP
Default Meth Logs, please review. - 01-22-2022, 12:35 PM
Moved the thread as the meth help thread is irrelevant right now. Looking to work my way up to 75 additive on 50/50 with E35. I can always add more M1 however I wanna try and get to 75 additive with 50/50 and E35. I sent over 40 additive logs and they were good. Attached is 50 additive logs. It’s at bottom of file. Let me know if it’s safe for me to turn it to 60 additive! Thanks. Logs at bottom of the file in 3rd gear and 4th gear
Car: M2 COMP
Default 01-23-2022, 01:32 PM
Update, No one had responded but looking at my timing boost and afr It looks like im safe to jump to a 60 additive and log, I'm unfamiliar with a safe AFR though looks like im between 12.5-14.0 on WOT. Im assuming this is safe. Correct me if I'm wrong. I will be uploading 60 additive logs tonight so please review and let me know if it looks good so i can bump it to 65 and work my way to 75 safely. thanks!
Car: M2 COMP
Default 01-23-2022, 08:12 PM
Here is my 60 additive log like I had promised, I don’t wanna go past this point without someone taking a look at my logs and giving me feedback if something looks unsafe. This was 4th gear on E40 and 50/50 meth
Car: M2 COMP
Default 01-26-2022, 04:22 PM
Car: Evo VIII
Default 01-26-2022, 04:50 PM
Please do not move threads as now we have to bounce back and forth.
I believe last requested was seeing E50 with a 60 additive.
As figured, timing is starting to break up at 6200 rpm.
What are all the modifications done to this car.
Car: M2 COMP
Default 01-27-2022, 10:30 AM
Dp, chargepipes, meth dual bm7. I can step up to a 70/30 blend but I’ll go ahead and try e50 first. That was e40
