n54e30t n54e30t is offline
Car: n54 e30
Default Bench flash firmware - 09-28-2020, 05:46 PM
Hey Guys,
Just wondering if its possible to bench flash the jb4.
Reason being is someone wants me to send them the jb4 pre-flashed and configured.
I assume i can power it with 12v to the power wire and ground through the black wire on large black subconnector.
Does anything else need to be connected?
Ancient8989's Avatar
Ancient8989 Ancient8989 is offline
Default 09-28-2020, 06:00 PM
Do you mean update or change the JB4 firmware? Just use the USB. If you mean something else I'm confused.
Car: n54 e30
Default 09-28-2020, 06:11 PM
Wasn't sure if it will power up using just the usb cable.
The jb4 isn't installed in a car.
Car: n54 e30
Default 09-29-2020, 05:59 AM
Confirm that supplying 12v to power and ground through black ground wire on large black subconnector is enough to power the jb4 on the bench to enable updating firmware.
