wasionman's Avatar
wasionman wasionman is offline
Car: 2007 BMW 335xi E90
Cool Ebay Fuel Injectors - 09-25-2020, 03:09 PM
Hey guys I just bough a set of NEW(supposedly) index 12 fuel injectors off of ebay. The injectors didnt come with a cap covering the nozzle. What do i need to do to install these injectors? Can I just throw them in or do I need to replace the seal(o-ring) around the nozzle? Help is much apprectiated!
BMS DCI, BMW Oil Catch Can, VRSF Chargepipe /w meth bungs, Turbosmart BOV /w Upgraded 1/4" Vacuum Line, VRSF 2" Inlet, VRSF 2" Aluminum Turbo Outlet Charge Pipe, VRSF 5" Stepped Performance Intercooler, VRSF 3" Stainless Steel DP, Becker Full Catback Exhaust, Fuel-IT Stage 2, Bucketless Low Pressure Fuel Pump, Brembo GT Big Brake Kit, JB4, MHD Back End Flash, XHP Stage 3, ST Suspension Coilovers, All New Silicone Vacuum Lines, UPGRADED 19T TWIN TURBOS
Car: 2010 135i
Default 09-25-2020, 06:08 PM
To do them right, look for a large brown container, top should flip open. Toss injectors in and buy a real set that aren't fakes.
Want to know a dead giveaway that they are fake?
Look at the coding data printed on them. You'll virtually never see 2 that are the same. If you end up with 6 that are the same, you got hosed.
But, every time you pull and injector you should replace the decouple ring and the seal. ALSO, be sure to reinstall the hold downs the correct way.
2010 135i auto,
NashN54 NashN54 is offline
Car: 2008 E90 335i Sedan
Default 09-28-2020, 11:01 AM
Watch this:
The SECRET To Replacing Index 12 Injectors FOR CHEAP on BMW N54 (135i, 335i, 535i) - YouTube
kd7iwp kd7iwp is offline
Car: 2009 535xi wagon manual transmission
Default 09-28-2020, 01:51 PM
If they all have different numbers you can certainly give them a shot. There's a tool kit that has a cutter to cut the o-rings and 3 dies to progressively shrink the new seals. I bought the kit from ECS and it wasn't particularly cheap for what it is, but works well. Then after you shrink the new o-rings and replace the decouplers you can pop them in and code with INPA. I bought a set of used index 12s locally and they work fine, though no different than my index 7/8s from before.
Car: 2010 135i
Default 09-28-2020, 05:30 PM
Jake spent too much on tools and ****.
This is the most cost effective injector tool --> PRECISION RACEWORKS - BMW N54 INJECTOR TOOL #601-0005
Have one myself. Works for VW injectors too I'm told.
2010 135i auto,
Default 09-29-2020, 09:28 AM
Thanks for sharing! That looks like a great tool and it definitely is cheaper.
Default 09-29-2020, 12:07 PM
You obviously didn't bother to watch the video...
He used a razor blade for seal removal, the head of one pen to stretch new rings out to install the new seals, and then another pen's cap to compress the rings down prior to installation. How are those expensive tools?!?!
Car: 2010 135i
Default 09-29-2020, 04:46 PM
Since spoon feeding is required for you,
and I guess looking back at PR's site, they don't have this pic and if you've never read about the tool I guess it could be overlooked
It's a injector removal tool (slide hammer), seal expander (cone), seal compression (3 slow stages) and has extra storage space for extra seals and rings.
2010 135i auto,
Default 09-30-2020, 07:31 AM
You are the one needing to be spoon fed. The OP's main question:
I simply pointed them to a guide that would help save money on installation, since they are obviously trying to do it on a budget.
He didn't ask for any tools, but you showed up anyways...
bmwboyee bmwboyee is offline
Car: 2007 335
Default 10-02-2020, 08:05 AM
I'm willing to bet the injectors are fake. Probably scratched out the index number and stamped a new one.
nhatnguyen14's Avatar
nhatnguyen14 nhatnguyen14 is offline
Car: N54 E89
Default 10-02-2020, 11:01 AM
they're junk. bought a set of 6 with the exact same numbers. had to buy them from fcp and it works great after that
