the_horak the_horak is offline
Car: 2018 Jetta, 1.4T, 5-Speed
Question Help a new guy out with Logs? Jetta 1.4T - 09-21-2020, 07:14 AM
Hey all! Recently got the JB4 for my 5-speed '18 Jetta with the 1.4T. I've been logging and making slight adjustments to MAP 6 because my car triggers the 20 PSI overboost safety if I don't.
Right now, depending on circumstances, my car tops out anywhere between 18.5-21 PSI. Doing a full throttle pull on an incline in 3rd starting at 1.5K RPM is when boost hits around 21. I know that 21 can be a bit sketchy with the stock turbo, so I want to make sure that things look healthy based on logs.
How should things like AFR, fuel trim, IGN 1 and other parameters respond with a healthy tune? I'm not asking for what numbers I should see (maybe aside from AFR), but what kind of trends I should see. Should I log with MAP 0 and then try to match the same trends?
I've got a modified intake (not a CAI) and a ***-back exhaust, so I'd assume those factors make a difference, as well. Thanks so much for the help guys. For what it's worth, I have some solid understanding of engines, but tune adjustments are all new to me.
Last edited by the_horak; 09-21-2020 at 10:41 AM.. Reason: The forum sensored the word *** in ***-back?? Again? Am I swearing and I don't know it? Haha
Default 09-21-2020, 10:18 AM
You want to see the IGn1 climbing as the rpm climb from around 4000 and higher. If it is doing step down of 3 you need to lower boost a bit.
If its touching 21 its ok but not holding it.
Biggest difference on these is octane.
Post map 6 settings and I can check if they are overboard.
Default 09-21-2020, 10:38 AM
Okay, thanks George. I can do that after work today. You want any logs, as well?
Default 09-21-2020, 01:33 PM
Dont mind having a look. Shoot them over to george@burgertuning.com
Default 09-21-2020, 03:49 PM
Emailed setting screenshots and logs
Default 09-22-2020, 12:35 PM
Just want to give an update that George helped me out. He's great!
