NihonX NihonX is offline
Car: 1M
Default Map 6 Review and Adjustments - 09-19-2020, 08:43 PM
2009 135i AT
10Gal 91 (unfortunately) / 4Gal E85
JB4 BEF (Pump USA)
D0wnplpes (oem mid), Intakes, FMIC, CP.
I am not hitting near boost and want to make adjustments in order to get there.
Any positive assistance would be appreciated.
I have posted three logs with everything the same but first log was of default user settings.
Car: 1M
Default Continued testing - 09-19-2020, 11:52 PM
I was able to get a 4th gear log.
This one looks better but any suggestions?
Car: 1M
Default Last One - 09-20-2020, 01:20 AM
This is my last log of the night.
Thanks again to anyone that can help.
AC Tuning AC Tuning is offline
Car: M4 Competition
Default 09-20-2020, 03:30 AM
I would check for boost leaks / hardware fault rather than trying to adjust. Also you are seeing quite abit of knock (5.4 degrees)
2018 Sanmarino Blue M4 Comp
Engine tuner
Bootmod3 dealer
http://www.actuning.co.uk
Instagram @ac_tuning
http://www.facebook.com/autoculture.tuning
Default 09-22-2020, 01:38 PM
Hey,
I looked at the last log you posted.
Couple things are jumping out..
LPFP is maxing out, I'd upgarde or replace ASAP. Until you can upgrade, I would run less ethanol or significantly less boost.
manually lower your FF from 150 to 70-80, and see if it learns back up.
At this point, I would not do any more logging until you address the LPFP.
