Jezabelle Jezabelle is offline
Default Missfire cylinder 6 - 09-19-2020, 11:03 AM
I've tryed new a new coil. Swaped cylinder 6 with 3 new injector on 6 and coded(old one didn't look bad but I had a brand new index to so I changed it all injectors are #12. Plugs switched 2steps colder. Car is fbo stock outlets and turbos jb4 with mhd backend flash stage 2 fuel it bucketless.
Only misfires over 6k on high boost if I target 16 after 6k it's fine e85 is about 50 mixed with 93
Default 09-19-2020, 02:14 PM
Here's another log. Doesn't seem to misfire Everytime I do a pull in 3rd but Everytime iam wide open shifting thru the gears it does...xhp stage 3 happens with padles or in sport mode,
Default 09-19-2020, 02:16 PM
Sorry here's a 2 3 4 log misfire happens in 4th
Default 09-21-2020, 07:22 PM
Update: fol adapted to 90 changed to 75 ran out of gas with a quarter tank🤔 put 5 gal of 93 in n didn't have my cable to change the bef. The car seemed way more powerful with out e85 didn't log i only got on it twice but is there anything I can change to make it faster iam fbo everything but outlets on stock turbos?
beamerbrad beamerbrad is offline
Car: bmw 335i n54
Default 09-22-2020, 11:29 AM
Probably dual mass flywheel on way out, that’s what happened with me, creates false knock when it gets warn and misfires start, if u Turn power up more you’ll get misfires on 5-4 cylinders to!
Default 09-22-2020, 01:22 PM
On an auto car?
Default 09-22-2020, 01:48 PM
What are the plugs gapped to?
Also the HPFP looks pretty stressed, do you feel any hesitation while accelerating?
I'd drop your ethanol content or lower boost.
Sounds like the car ran better with more 93, which supports my initial concern that their is too much e85, and the fueling cant support.
Default 09-22-2020, 04:14 PM
Plugs 2steps colder gaped to .020 my ethonol content was under 40 I usualy run 60 without hesitation or any trouble realy and I have a stage 2 bucketless lpfp...do you think my hpfp might be on the way out? What number should I be looking to hit on hpfp?
Default 09-29-2020, 12:05 PM
Ideally we don't want to see your HPFP value dip below 10
