boostedloony boostedloony is offline
Car: 07 335i
Default Fuel pressure - 09-12-2020, 09:22 PM
So I just replaced my lpfp with precision raceworks 2.5 kit and I'm still getting kicked for low fuel pressure is my hpfp going out hows it look to you I just want my car back to normal
Car: 07 335i
Default 09-12-2020, 09:38 PM
Throttle valve angle manifold vacuum correlation as well as o2 codes but I figure that's ******* dp let me know if you think it's not and what I need to look for please
Default 09-15-2020, 09:50 AM
HPFP looks to tank hard on initial onset
Car: 07 335i
Default 09-15-2020, 10:06 AM
Is that pump or regulator related and it doesnt kick me until like top of 3rd or 4th that's where the other part of the issue is but yes watching my hpfp on jb4 I can see it drop as I put my foot down the car hesitates and then goes and pressure comes back up
Car: 07 335i
Default 09-15-2020, 06:01 PM
I also have a spare lpfp sensor that it tried and that one reads 58psi put original back in and it still reads 64 65 at idle does the regulator leak so the lpfp cant feed the high or does it seem all hpfp related
Car: 07 335i
Default 09-15-2020, 06:09 PM
Low pressure only drops 2psi when car is shut off leading me to believe the regulator should be fine but the high pressure drops from 5 at idle to 2 when the car is shut off does that mean its leaking internally and not holding in the pressure it needs to or is that not how that works I'm stumped guys
Default 09-16-2020, 10:20 PM
All your symptoms + the logs show the HPFP is shot or very tired
Car: 07 335i
Default 09-17-2020, 04:28 AM
Ok I'll try another one heres a log from this morning on the way to work the top looks ok but in the beginning the high pressure really does seem to dip then come back on so I will change it let me know if you see anything else in the log that is of concern I have a dyno day on sunday and want full potential
Default 09-17-2020, 06:10 PM
what is the ethanol mix?
HPFP on tip in looks really low
Fuel trims are also maxed from basically 3k and on.
Did you install the flash?
Car: 07 335i
Default 09-17-2020, 06:15 PM
E50 on these runs I'm going down to e30 and putting on the hpfp and yes I have the race bef
Default 09-17-2020, 06:42 PM
Lets drop you down to e40 first, let's see if we can get the HPFP to hang w. some lower ethanol
Car: 07 335i
Default 09-17-2020, 07:19 PM
Ok will do tomorrow after work about 6 should be able to have a log up by 630
Default 09-22-2020, 01:26 PM
Sounds good.
