Krivero9 Krivero9 is offline
Car: 2007 bmw 335i
Default ** SOLVED **29dc cylinder injection switch off low fuel pressure - 09-04-2020, 12:02 AM
I have very low fuel pressure at high rpm under wot or close to it. It seems my lpfp is taking a big dip and consequently my hpfp. The car is on full E but has a stage 3 walbro 450 pump. Could it be going out? Bad lpfp sensor? Link to the log below
https://***********/sites/default/fi...00903_1921.csv
Car: 2007 bmw 335i
Default 09-04-2020, 12:06 AM
http://***********/u/krivero9/wot-3r...log=0&data=1-4
Default 09-04-2020, 08:29 PM
We don’t use 3rd party host sites.
Can you just upload the JB4 CSV
Car: 2007 bmw 335i
Default 09-04-2020, 09:20 PM
This should be it
Default 09-05-2020, 10:36 AM
HPFP can’t take the full e
Dilute your mix ASAP
can you provide me with more setup details? Turbo etc.
Car: 2007 bmw 335i
Default 09-05-2020, 02:50 PM
HPFP canít take the full e
Stage 3 dual walbro 450, jb4 integrates port injection, on3 67mm, car is on jb4 and mhd backend flash. Previous owner said he just put full e and it was alright.
Default 09-06-2020, 07:40 AM
Based on these logs...
Doesn’t look like your PI is turning on...most set FOL to 0 if they have PI
HPFP is tanking, double check you have the PI bet installed & set your duty bias to 60 across board
Car: 2007 bmw 335i
Default 09-07-2020, 10:42 AM
We donít use 3rd party host sites.
This is 3rd gear and jb4 sent me to safety map because of low pressure. Diluted mix to straight e60 because thatís what bef was. Set duty bus to 60 and fol to 0
Default 09-08-2020, 10:21 AM
yea something is up.
HPFP tanking & your LPFP is crashing HARD.
Car: 2007 bmw 335i
Default 09-09-2020, 08:21 PM
Not exactly 100% was solved the issue but the night before, I added stp fuel cleaner to my 1/4 tank. Next morning I wiggles around jb4 connection wires and made sure they were all good. Checked to make sure my fuel pump and filter werenít leaking from any obvious locations. Then what I think was the culprit, I was going to disconnect the battery so I can mess with the jb4 and saw what I think was the positive connection for either my Hobbs switch or secondary fuel pump. It was hanging on by a couple wires so I reattached and made sure connection was solid. Drove the car 2 days after all this and could once again go WOT without low fuel pressure or injection cuttoff. Lpfp stays above 65 psi and hpfp around 11 at high rpm.
Default 09-10-2020, 03:49 PM
Phew!
If you want to throw up some logs with everything working, we can turn things up.
Car: 2007 bmw 335i
Default 09-10-2020, 04:18 PM
Phew!
Hereís one!
Default 09-11-2020, 05:03 PM
Keep an eye on the LPFP, that nears the 50's up top.
Up the PI from 4k to redline by 5
Car: 2007 bmw 335i
Default 09-11-2020, 05:05 PM
How do I do that?
Default 09-11-2020, 05:09 PM
How do I do that?
go into your user adjustment settings, and update the fuel bias #s
Car: 2007 bmw 335i
Default 09-11-2020, 06:56 PM
Will do, thanks Dave!
Default 09-12-2020, 06:41 PM
No problem. Keep me posted, and monitor the trims on your logs after the fuel bias changes.
We want to see your trims trending DOWN from 50
Car: 2007 bmw 335i
Default 09-13-2020, 09:40 AM
Definetly helped at 4500 when I used fuel bus by 5 but then started climbing again after that
Default 09-15-2020, 09:53 AM
Bump the fuel bias up more from 3.5k to redline
