ram00sa ram00sa is offline
Default 2AAF CODE - 09-01-2020, 05:58 AM
I bought a 2009 335i with DCT.
When I park the car at an angle I see the car dripping fuel after fill ups. And the fuel tank won't fill beyond 3/4 after a while I had some severe misfire under WOT with some flames and it feels like I hit a wall
Now the car will go in limp mode and struggle I when I go past 10% throttle .
I did some logs today
The low pressure reading jumps rapidly between 40 to 60 when I put any throttle and stays in the low 40s with no thortle
Have any experience the same issue.
I have fuel it stage 2 pump
Just to add when I opened the fuel regulator cap I saw wet dirt.
wwwROLL TIDEwww's Avatar
wwwROLL TIDEwww wwwROLL TIDEwww is offline
Car: 08 535i
Default 09-01-2020, 06:19 AM
Sounds like the fuel regulator/filter may have gone bad.
Fast Chet is a 2008 535i Sport+
JB4 G5 ISO, MHD BEF (pump)
BMS DCI
VRSF CP w/ Tail BOV
VRSF Kittenless DP
VRSF 7.5 Race FMIC
VRSF Outlets
RB Gen Two Plus Turbos
RB Inlets
Fuel-It DW400+ LPFP
Helix HPFP Overdrive Unit by Spool-it
Default 09-01-2020, 09:47 AM
this assolation of the fuel pressure could be caused by the reg ?
Car: 08 535i
Default 09-01-2020, 09:55 AM
I would start there especially since you observed wet dirt on it. It could have a crack in the plastic or a bad seal. Just a thought.
BMS DCI
VRSF CP w/ Tail BOV
VRSF Kittenless DP
VRSF 7.5 Race FMIC
VRSF Outlets
RB Inlets
Fuel-It DW400+ LPFP
Default 09-01-2020, 10:15 AM
if the filter is contaminated, couldn't be cleaned using fuel additives or even physically or buying a new unit is a must.
Car: 08 535i
Default 09-01-2020, 10:20 AM
I am unaware of a cleaning procedure. However, I just had a customer with same issues leaking fuel also and it was the regulator/filter unit. We replaced it, now no more leaking and the car is able to get the fuel to the rail.
BMS DCI
VRSF CP w/ Tail BOV
VRSF Kittenless DP
VRSF 7.5 Race FMIC
VRSF Outlets
RB Inlets
Fuel-It DW400+ LPFP
Default 09-01-2020, 10:22 AM
aha so he had the same codes, and car will go into limp mode as soon he demands power from it.
Car: 08 535i
Default 09-01-2020, 10:53 AM
Correct
BMS DCI
VRSF CP w/ Tail BOV
VRSF Kittenless DP
VRSF 7.5 Race FMIC
VRSF Outlets
RB Inlets
Fuel-It DW400+ LPFP
Default 09-01-2020, 10:56 AM
parts on order
Default 09-23-2020, 08:00 PM
i replaced the fuel filter, the problem is still there however the fuel pressure from the low side is steady 65 to 70, however the high pressure is ready 6 units of reading on the jb4 app, and when i hit the gas it drops to 2 and goes into limp mode, any ideas ?
Default 09-29-2020, 12:08 PM
Can I see a log?
