johntotah94 johntotah94 is offline
Car: B46 F56S
Default Solenoid or Check Valve? Mine failed - 03-17-2019, 04:14 PM
My solenoid on my BMS meth kit stopped working for some reason.
I was diagnosing why I knocked the other day and realized there was no more flow. Iíve done all the diagnosis and needs to be replaced.
I get flow before the solenoid and after is dry. Iíve tried manually opening the solenoid with power and ground with no success. I do hear the solenoid ticking as I take it on and off power but can not get it to flow anymore.
Anyways, Iím wondering if I should just replace my solenoid with a check valve. Or go with a replacement solenoid?
Thoughts?
truittkeeler truittkeeler is offline
Car: 2020 Stinger GT2
Default 09-30-2020, 02:21 PM
I realize this is an old post.
I had my solenoid fail, Burger sent me a replacement. 4 days later that one failed. I triple checked the install, everything is exactly how it's supposed to be. I was also wondering the same thing about a check valve. What did you end up doing? My buddy just gave me a different solenoid from another meth kit. So far so good. When it's activated it clicks allot harder than the BMS solenoid. I'm awaiting a reply from Terry now on the next steps.
