baconNgritz baconNgritz is offline
Car: 2007 BMW 335i
Default Map 5 target boost too high? - 09-17-2020, 10:07 AM
While datalogging trying to pinpoint a throttle oscillation issue, I happened to notice my boost target was 19.5psi and I was peaking just over 20psi.
Read through the " E Series N54 JB4" sticky, it stated that peak boost should be 17psi on map 5. Hoping I can get some guidance on why this is happening, and if I should move to a different map.
Running 93 octane, VRSF chargepipe & DP's, BMS DCI, HKS SSQV bov, and Circuit Werks exhaust.
Thanks in advance.
Default 09-17-2020, 06:33 PM
Flash?
Can I see map 1
Car: 2007 BMW 335i
Default 09-18-2020, 07:40 AM
The previous owner didn’t mention a flash, nor did the car come with the equipment to do so. I’ll try and grab some Map 1 pulls today.
Car: 2007 BMW 335i
Default 09-18-2020, 10:19 AM
Got out and did a few more pulls in drive and 3rd. On the second run in drive, it pushed me in to Map 4 for overboost I believe. Here's the logs.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-18-2020, 11:02 AM
Your hpfp drops in some of those logs and your lpfp drops into the 40’s and 50’s. I would definitely address those especially if that’s on 93 fuel.
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
MISHIMOTO 25 ROW OIL COOLER
MISHIMOTO 15 ROW TRANSMISSION COOLER
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
Car: 2007 BMW 335i
Default 09-18-2020, 12:20 PM
Originally Posted by Rule77
Your hpfp drops in some of those logs and your lpfp drops into the 40ís and 50ís. I would definitely address those especially if thatís on 93 fuel.
I noticed that, luckily it seems that the AFR's and trims are still acceptable. I have gotten the fuel pump probability codes in the past, wonder if the LPFP dropping down is what's causing the HPFP to drop pressure? I'd really hate to have to do both.
Although, the fuel pressures still don't answer the boost target issue.
Car: 2007 BMW 335i
Default 09-21-2020, 11:05 AM
Is there a way to check for backend flash without having the MHD or other module?
Default 09-22-2020, 01:42 PM
Not really. Best way is to read what is currently flashed on the car
Car: 2007 BMW 335i
Default 09-22-2020, 01:55 PM
Would the current boost targets lead you to believe its been flashed? Or is there another possible cause?
Car: 2007 BMW 335i
Default 09-29-2020, 06:07 AM
Which product would you guys suggest as a start for checking for a flash?
