N52german N52german is offline
Car: 06 E90 330i German Version
Default Infamous 4 5 6 misfire!!! HELP SOS! - 09-07-2020, 10:52 PM
Hi, im new here, i have a 07 E92 335i German spec N54 Duuh, i bought this car with some issues, the car only has 28k miles, from day #1 30FF error, completly stock car, and several misfires and 4 5 6 and at idle sounds like a 2 cylinders are gone, jerky, slow, not boost and 30FF, to fix some issues in the car, i changed the thermostat, bank 1 before *** 02 sensor, and i installed VRSF DP, VRSF inlets, VRSF intakes, Delphi coils, 2 step colder spark plugs (yes, gapped) Extreme Turbo System 7" IC, Vargas Turbo chargepipe, Turbosmart BOV, STOCK TUNE. When i changed the coils and spark plugs i thought my issue was there, but nope, i bought the BMW special tools to remove the injectors clean it and put new seals and rings, they are little dirty, i cleaned and the same idle misfire, same codes, new battery, same codes, i removed the intake manifold and there is some carbon there, i cleaned the carbon, like new, same idle and errors, i swap my index 10 injector with a friend who has a perfect stock 335i with index 09, i use my scanner to set the injectors part numbers, start the car, same thing! those days i had to change my fuel pump, the plausibility error came in, put a new 450 fuel pump, the car feels the same, my lower pressure is 70ish psi under wot, cruising, etc, never have a long start in the morning or so, so now im stucked, today i made some logs with MHD (just log, NOT tuned DME) and the car i making 7psi and the bank 1 afr at wot is 12.5 to 13 and bank 2 extremely lean, 17+, so what the hell is happening with my car? any wiring issue?? i made 660whp in my 2008 Honda Civic and i sold all my turbo kit to buy this thing, now you can imagine how i feel right? this is my second language im sorry, SOS please HELP ME!!!!!!!!!!
BTW i checked my DME, and the 6 mosfet are good!!!!
Jamesholden Jamesholden is offline
Car: Bmw e92 335i
Default 09-09-2020, 07:31 PM
Maybe a compression test will help or leakdown test...
Default 09-11-2020, 04:58 PM
Hey,
So based on the info provided, it sounds like your bank 2 sensor is out of whack, why did you only replace bank 1?
I'd inspect that bank 2 sensor, and swap it out.
Default 09-14-2020, 09:44 AM
Hey,
The car had CEL for bank 1 sensor, thats why, ill swap it bro, thanks a lot
Default 09-15-2020, 10:00 AM
Keep us posted, but that should do the trick.
Replace, do an o2 reset & log
