Jscottrad Jscottrad is offline
Jscottrad
Car: 2007 335i
Default Lost Boost - 06-11-2019, 08:11 AM
I've read and done all the common checks. No boost leaks, replaced vacuum lines for waste gate control. Thought I would get a second opinion while I wait for my new boost solenoids to show. PWM is 99 but I'm slow to spool and only reach about 10psi. Vargas turbos with billet compressor wheel (20% more boost according to them) I hit the 17psi target in map 2 normally with no problems. All the normal mods. Any advice is welcome.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 06-11-2019, 08:59 AM
Did you check DV vacuum lines? Reminds me of when one of those is disconnected.
Jscottrad
Car: 2007 335i
Default 06-11-2019, 10:58 AM
DV's are in my back yard shed. checked vacuum to blow off valve and made sure valve was sealing tho...
Jscottrad
Car: 2007 335i
Default 06-11-2019, 02:31 PM
Finished replacing all vacuum hoses and both bleed solenoids, still no help. while looking for a leak downstream of the turbos noticed when running there is oil vapor coming from rear air inlet. I have an air oil seperator installed. Could I be losing boost to the PVC system?
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-11-2019, 02:43 PM
Did you check wastegate movement while applying vacuum with a hand held vacuum gun or measure vacuum at the boost solenoids?
N54 WG Vacuum Line Testing HOW-TO - YouTube
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Jscottrad
Car: 2007 335i
Default 06-11-2019, 03:07 PM
Yes, and on start up both waste gates go full closed, unplugging boost solenoids makes them return to wide open
Jscottrad
Car: 2007 335i
Default Found the problem... - 06-12-2019, 02:28 PM
Time to rethink which turbos to buy...
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-12-2019, 03:23 PM
Yikes!!!
07 E90 AT - xHP
FBO
Hybrids
Default 06-13-2019, 10:36 AM
whoa..
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Pessimistic Poster
Car: 135i N54
Default 06-13-2019, 03:57 PM
Vargas strikes again!
How many miles on those?
