Danny3363 Danny3363 is offline
Car: 2009 E92 335i Space Grey
Default 29DC code Hellllp 👍🏻👍🏻👍🏻👍🏻👍🏻��🏻 - 07-02-2019, 10:57 PM
Hi guys could anyone help me determine what is causing my 29DC code?
Iíve attached a .cvs file I am also on the latest firmware version and fuel open loop is set down to 70 from 89
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 07-03-2019, 08:33 AM
Was the code triggered near the end of this log? Both LP and HPFP look a bit ragged at times. It dropped bigtime during the last part of the log when you stepped on it in 2nd.
Edit: looked more closely at the log file and you triggered a safety for low fuel pressure (high). LPFP dropped a lot too, but probably not enough to starve HP, so might be a HPFP issue.
Default 07-03-2019, 09:24 AM
Yes it was the second time I did a wot run in that log that it triggered the 29DC code so you reckon both are not optimal? Terry told me hpfp but as itís a big expensive job and time consuming to do I just wanted a second opinion even though I thrust him implicitly
Thank you for your input
Default 07-03-2019, 09:43 AM
Do you think any of this could be simply caused by the fuel pressure regulator in the tank failing and being unable to maintain a decent pressure?
Default 07-05-2019, 08:27 AM
How many miles on car?
Hpfp isn’t a huge job, but I beleive a new hpfp is relatively expensive new.
