Remedize Remedize is offline
Car: 2008 E92 335i
Default SOLVED - 06-08-2019, 12:05 AM
you ruled out a small to moderate sized boost leak as well, correct? System was pressure tested etc.
Originally Posted by miksebik
something new? Would like to know if it is Pure thing or something else...
*UPDATE*
Turned out to be my exhaust. Must have been too restrictive or something. OEM exhaust (no secondary cats just resonators) lol
What I did to test was unbolt the ********* from the exhaust and did some logs.
Loud as hell but she actually overboosted to 31psi and it scared the hell out of me for a sec lol I had to dial duty bias waayyy back across the board and bring ff from 120 to 60 to not overboost past 25psi.
Default 06-08-2019, 10:54 PM
Originally Posted by Remedize
Im saying in the log the ff gets pegged at 78 and doesn't change.
Pure just told me that it has to be a boost leak somewhere thats all they said.
Hmmm.
Do you have lift access?
Car: 2008 E92 335i
Default 06-10-2019, 07:47 PM
Hmmm.
I donít, but I did solve the issue. Check OP
Default 06-10-2019, 10:50 PM
Interesting?!
Ready to see some logs then
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 06-11-2019, 09:07 AM
That is really strange, are you sure there was no obstruction?
Car: 2008 E92 335i
Default 06-11-2019, 05:29 PM
Interesting?!
Heres a log running open d.ownpipes...
Duty bias had to be adjusted WAY down and FF from 120 to 60.
Just some small duty bias adjusting and it would be perfect.
2019-06-06 17_08_13_Map-6.csv
Car: 2008 E92 335i
Default 06-11-2019, 05:31 PM
No obstructions at all
