TheCondor TheCondor is offline
Car: Mini JCW 2022
Default Log review please MINI JCW 2022 - 08-11-2021, 12:12 AM
Hi, any advice for better performance? Car is totally stock (brand new, just 2.000 km), 95 RON fuel.
Default 08-11-2021, 10:02 AM
Those appear to be corrupted...please upload the original CSV file and do not open or save it in excel.
Car: Mini JCW 2022
Default 08-11-2021, 10:06 AM
try now, thank you Steve
Default 08-12-2021, 12:03 PM
That's better...
Trims are maxing out so you can't add any ethanol. Give map 2 a shot and lets see how that looks.
Car: Mini JCW 2022
Default 08-13-2021, 02:37 PM
Thanks Steve for your reply, your supporto Is the very plus or th jb4. Here a map2 with 100octane fuel, not so simple to find here around... Thanks
Default 08-16-2021, 12:20 PM
Log looks pretty clean but same thing, maxed out trims so don't add any ethanol.
Car: Mini JCW 2022
Default 08-16-2021, 01:20 PM
Thank you Steve for your review! That's not a problem: here in ITA we don't have ethanol at the pumps on the road. With map2 i can feel a stonger acceleration, the car keep pulling. Do you think i can try map3 or something else? Or lowering to 95ron common fuel?
Thanks again?
Default 08-17-2021, 10:14 AM
On the 100 octane, yes you could give map 3 a shot and log it for review. If going back to 95 octane I'd stick with map 1 or do a log on map 2 for us to evaluate.
Car: Mini JCW 2022
Default 08-18-2021, 06:28 AM
Here a map3 with 100 octane for your evaluation. Next time i'll be back to the pump i'll upload a map2 with 95 octane. Here in Italy 100 oct. is only at few pump, ethanl does not exist. 95 octane is the standard gasonline.
Default 08-18-2021, 11:02 AM
I don't see any issues...your logs are kind of short (not o redline) and some aren't at WOT though. Trims are still maxed out.
Upload a log of map 2 on 95 and I'll check it out.
Car: Mini JCW 2022
Default 09-15-2021, 06:24 AM
Hi, here a 3 gear with 95 octane gasoline. Around 1218 timestamp there's a 3 gear and around 2954 a 4 gear sprint. There's a lot of traffic here :/
Map3 with 100octane is really impressive, but if it's safe i'll stay with map2 and 95 octane for everyday usage. Thanks since now for your review.
Default 09-15-2021, 10:06 AM
Nothing attach...
Car: Mini JCW 2022
Default 09-15-2021, 01:01 PM
Nothing attach...
Sorry, now It Is. It's with firmware v20 which seems more smooth to me.
Default 09-16-2021, 06:50 PM
Log looks pretty good but trims are maxed out so AFR's are running real close to stoich. Otherwise it looks pretty normal.
Car: Mini JCW 2022
Default 09-17-2021, 01:17 AM
Thanks for the review, if I understand correctly also in Map1 with 95oct (or map2 or 3 with 100) is pretty close to stoich. Trims are maxing so working on the air side is out....
probably this new b48 are setted to stoich afr for green emission limit and there's not much to do without working on the ECU directly when (and if) it will be unlocked
Car: Mini JCW 2022
Default 09-17-2021, 02:32 PM
For close the loop, here two run on map3 with 95 octane.
Map 3 seems more smooth to me, Also the turbolag Is lower, the car seems ready Also at lower rpm.
At the end of the second run jb4 was on map8-valet
Default 09-20-2021, 09:06 PM
Trims are maxed out and you are running lean. I'd recommend sticking with map 2.
Car: Mini JCW 2022
Default 09-24-2021, 03:17 PM
Thanks for your review Steve, i'll Stick to map2 with 95 oct and eventually switch to 3 when i run 100 oct
