timothy2001 timothy2001 is offline
Car: 2011 335i E90
Default Installed JB4 yesterday - 04-05-2015, 05:18 AM
Been hanging out at E90Post and have been on fence about installing a Tune and this is fantastic.
2011 N55 E90, no issues whatsoever with install.
It occurred to me that modding up my car and then driving it is like taking drugs, no ****. Want more!
Installation was easy, very easy and went off without a hitch and I didn't even break anything.
I run 93 Octane and have CP, FMIC, Injen Intake and my ******* DP is well, it's still on my back seat because I still need to find someone to install it.
I only ran Map 1 yesterday so I am wondering if I can run Map 2 and what about Map 5? Says "Autotuning" but pretty sure I have read that Map 5 'learns' your set up and configuration and adjusts to your car? Maybe that is what "autotuning' means.
I've got the cable, I guess I should pull some data logs to either bench mark where I am or look for any anomalies.
Now I am setting my sights on the Pure Stage Turbo next. We'll see about that.
This just goes to show you're never too old to play with toys!!!!
Mustang GT's are a dime a dozen around here and just asking for a beat down but sanity always prevails.
CJ2 CJ2 is offline
Car: 335i F30
Default 04-05-2015, 05:40 AM
Grab some logs in map 1. Post them in the support section to make sure everything looks good. Then progressively jump to the next map based upon your mods, and continue to log and post in support section. Always good to be safe and have someone double check how things are running.
--Get your DP installed and maybe pick up some flex fuel wires so you can run an e85 mix (up to 40% on your E series). The higher octane will allow you to run more boost.
2013 F10 M5 | PS2 | JB4+BCM | Bootmod3 | BMS Intake | BMS CP's | ER **'s | SSP Spec-R | Meth
10/15/16 Goodbye old friend - 2012 F30 335i | PURE stage 2 turbo | JB4 | BMS intake | ER down pipe | ER charge pipe | ER FMIC | E60 | Meth
Felipe666 Felipe666 is offline
Default 04-05-2015, 05:41 AM
map 2 wich is 93 oct is better than map 5 i only un map 5 if in some case i was almost out of gas and the quickest gasstation available only had 91 oct ....map 5 turbo lbs peek are really low....map 2 lbs peeks 14 and some times 15
NJCarGuy's Avatar
NJCarGuy NJCarGuy is offline
Car: 2013 335i E93
Default 04-05-2015, 06:42 PM
Congrats on your JB4! I've had mine for 6 months and love it. My setup likes map 5 but I'm FBO and often run E30. Install you DP and compare your logs in both maps 2 & 5 after you post your map 1 logs for review like CJ2 said.
Garage:
2020 X3M Comp - JB4
2011 X5 50i M-Sport - Dinan Stage 2
2002 M3 6-speed, Euro Cams, RE Exhaust, Intake, Dyno Tuned
2016 i8 - Installed K&N filter. Looking for mods
2015 X1 35i - FBO, Pure S1 Turbo + Meth
Turbo_chris Turbo_chris is offline
Car: E90 335i/6 Msport
Default 04-06-2015, 05:44 AM
That's falso info. Map 5 is a auto tuning map and can run much higher boost compared to map 2 if you have enough octane and properly teach it in. 3-5 3rd gear pull starting at 2k rpm's will net much higher boost than map 2 if you have enough fuel/octane.
2010 535i - 2012 X5D - 2010 GL550 - 2005 Porsche Cayenne S
Car: 2011 335i E90
Default 04-06-2015, 07:06 AM
Guys thanks for these replies, a bit of a learning curve for me.
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 04-06-2015, 12:27 PM
This is correct. I've seen 19psi on map 5. If it's targeting less than map 2 it's for a reason.
