r6xual r6xual is offline
Car: F30 335i X Drive
Default Question regarding meth flow on maps. - 08-25-2014, 11:52 AM
I have the BMS meth kit isntalled. Is map 3 the only map that flows meth? If not, which maps flow meth?
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 08-25-2014, 12:56 PM
Maps 3, 6, 7 by default. Please read this
http://www.n54tech.com/forums/showthread.php?t=22272
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 08-25-2014, 01:27 PM
Originally Map 3 was a dedicated Meth Map, identical to the auto-tuning map 5 but with meth support.
Currently you can unable meth flow on all maps. So you can run map 1 and you will get a benefit of cooler air charge but no boost additive.
Map 3 with 65-75 boost additive is equal to Map 7.
Daily: G30 M550i JB4
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPPK front & 50i rear brakes, M50d grill and trim
Gone: E92 N54 468wtq
quick99si quick99si is offline
Default 08-31-2014, 12:28 AM
Map 3 is map 1 plus boost additive AFAIK. It has lower boost targets than nap 2, but the difference is more than offset by the additional boost from the meth setting.
VRSF DP | VRSF 7" FMIC | ER CP | HKS BOV | BMS DCI | BMS OCC | JB4 G5 | CM10 | Alpina B3 Trans Flash
