Jnat Jnat is offline
Car: 09 335xi
Default Alpina b3 flash queston - 08-11-2014, 06:33 AM
After this flash, when in DS mode, does the transmission automatically upshift to 6th gear or does it stop at 5th like it does now stock? I've read and I'm still unclear on that for some reason?
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 08-11-2014, 06:48 AM
It will shift to 6th.
|2007 E92 SGM 335i|
Cobbv3 BMS DCI & OCC VRSF *** & FMIC E85 Custom Backend & Alpina TCU flash ER CP RB PCV+Cap
Walbro 255 Rohana RC5 19s Nittos 555 245/275 Cyba Scoops LUX V3 M3 Cowl ST Coils LCI Tails
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 08-11-2014, 07:01 AM
at 80 I believe.
JP.Williams JP.Williams is offline
Car: E93 335i
Default 08-11-2014, 08:05 AM
I like the fact it stays in 5th normally!
(when stock at least) much easier for picking up speed on motorway.
6th should be for cruising only which you wont be doing in "sports"
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 08-11-2014, 11:33 AM
75-80mph it will shift into 6th. If you've leveled out on the highway & in cruise control, just flip it back into D & it'll jump to 6th. At least that's what I do, if I see I'm steady state and tachin' up & want to shift. If I need a little extra power, I can manual downshift & it will return to automatic mode from D, or slap it back over to DS.
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, GoFastBits DV+, Ethanol Content Sensor - No problems up to E70 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
ajsalida ajsalida is offline
Car: e92 335xi
Default 08-11-2014, 01:36 PM
It will never shift into 6th in DS mode under 74 mph under any conditions. It will hold 5th under moderate throttle over 74 but quickly shift into 6th when letting off the gas. Downshifts back into 5th under 74 always. Or at least that is my experience so far.
chiaobaby chiaobaby is offline
Car: 335I
Default 08-12-2014, 05:49 AM
Made to cruise on the Autobahn
Car: 09 335xi
Default 08-13-2014, 09:34 AM
I've read mostly good about this, some bad. I love sport mode, is the flash much better?
tboudre's Avatar
Default 08-13-2014, 10:38 AM
I put by Alpina flash in nearly the first thing & have been driving it like that for 6 months+. I just got the JB4 & am still mostly stock running E85 mix. DS it the BEAST now! I think the Alpina B3 stock is around 400bhp. I think as you approach that with mods, you're getting what the program was designed for. It feels really aggressive now, almost too much for city driving, I've been bringing it back to D lately, and with the added HP, D doesn't feel as mushy.
