matts335coupe matts335coupe is offline
Car: 2009 BMW 335i Coupe
Default EWG harness install - 06-30-2014, 07:20 AM
Who has installed there EWG harness and how long did it take? I just got mine over the weekend, super fast shipment and it looks great! I was quoted $225.00 to install it at a time of over2 hours. Sounds a little crazy to me, the tuner only took 30 minutes to install. Does it really take that long for the install?
MarinoB's Avatar
MarinoB MarinoB is offline
Default 06-30-2014, 07:48 AM
That's ridiculous. Depending how small your hands are it's a 15-30 min install.
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Kind of what I figured. Sounded a bit sketchy.
sonystyle02 sonystyle02 is offline
Car: 2014 BMW 435i M Sport
Default 06-30-2014, 08:27 AM
I was quoted $65 by a very reputable SoCal shop. Definitely go somewhere else.
Default 06-30-2014, 08:28 AM
Do you feel a real difference, the jb4 alone on my car feels almost the same as stock.Barely notice any difference in power.
Default 06-30-2014, 08:34 AM
This was my progression:
- Stock + JB4 map1
- Intake/dp + JB4 map2
- Intake/dp + JB4 map5
- Intake/dp/catback + JB4 map5
I felt a difference with each upgrade. Dyno'd stock vs. bolt-ons vs. bolt-ons + JB4 and it showed a significant increase in HP/TQ. I'm getting the FF and EWG wires installed Thurs and will have dyno runs pre and post install.
I'm running 91 octane.
Default 06-30-2014, 09:29 AM
If boost is below target the EWG will definitely get it back up to where we intended it to be!
Default 06-30-2014, 09:31 AM
awesome! I am not doing any other mods, is the EWG still going to be affective? Also on these new F30/32 can you run Map 2 on 93 octane without ***?
Default 06-30-2014, 09:32 AM
The EWG is BETA/experimental and we'll see how customer feedback is without mods, etc. It's too early to really tell.
Default 06-30-2014, 09:34 AM
Gotcha. Well from everything I hear, it's amazing!
Default 06-30-2014, 10:17 AM
The only thing left is to fix the startup code that shows up in some cars when starting without turning on ignition first.
JustinCredibleM's Avatar
JustinCredibleM JustinCredibleM is offline
Car: M235i
Default 06-30-2014, 01:03 PM
It took me 15 minutes to do it in my garage - its really not hard at all.
2015 Alpine White M4
EuroprojektzF30 EuroprojektzF30 is offline
Car: '14 335i EBII MSport
Default 06-30-2014, 01:29 PM
Its an extremely simple install. The most difficult part was trying for 15-20 minutes to get the original clip undone. It is extremely tight quarters, so maneuvering your hand in there to get the clip off is pretty hard and I have a few bruises on my arm to prove it The rest of the install is easy peasy.
With that said, It is ENTIRELY worth it. It's night and day difference versus NOT having it. The car feels MUCH stronger and smoother with the harness. Terry and the guys really did a great job here.
Car: M235i
Default 06-30-2014, 01:56 PM
I got a 1.5' screwdriver and just leveraged it against a coolant hose to press against the clip and pulled it out. It should take a few minutes to do that assuming you are able to pull on the plug and press the clip at the same time.
Abear Abear is offline
Default 06-30-2014, 02:21 PM
How did everyone route their wires? I would think they would get pretty hot right there.
tibookM3 tibookM3 is offline
Car: E92 M3, F32 435Ms
Default 06-30-2014, 02:26 PM
The other wires are just hanging out there as well and they seem ok. I wouldn't sweat it.
BMS JB4, Intake, FF and EWG harness, M Performance Exhaust, ER coated DP/CP, and a barrel of 104 octane
Car: M235i
Default 06-30-2014, 03:09 PM
I covered it up with the same material you'd find on the JB4 wires for peace of mind.
Default 06-30-2014, 03:11 PM
As did I, even though I doubt it really makes a difference. Looks nicer though
Car: M235i
Default 06-30-2014, 03:13 PM
Yup, looks more stealth :D.
Default 06-30-2014, 03:27 PM
Just make sure they are not testing on anything too hot but should be fine. We'll be evaluating that as well.
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default 06-30-2014, 04:47 PM
Took me 5 Mins total and 15 mins to heat wrap the wires for extra insulation and neatness. Is it worth it ..... you bet !!
M135I ER Down-pipe & charge pipe ,Milltek full system,Wagner Performance Intercooler AFE Stage 2 Intake Pure stage 1 Turbo & Quaife LSD
Alpine435i Alpine435i is offline
Car: 435i
Default 07-01-2014, 11:24 AM
Just ordered my JB4 with EWG/FF wires and will have my dp installed all at the same time at FFTEC.
Terry/BMS, what are all the parameters that need to be changed/set up initially with a laptop to get everything good to go? Also, with just an aFe intake, JB4/EWG/FF, ER dp, I will use 91 octane nearly all the time, with the occasional 100-octane mixed in (maybe once a month or every other month just for kicks). I'm looking for a more set-it-and-forget-it setup, so should I run Map 5 and let it just do its thing? Or would Map 1 be the way to go?
sootyvrs sootyvrs is offline
Car: BMW M135i N55
Default 07-02-2014, 04:56 AM
Can I ask what extra insulation you guys have used? Any pics of the installed harness on N55 (M135i preferable) Thanks
Any issues with putting the 2 pins into existing JB4 connector?
Chaddy74's Avatar
Car: M135i
Default 07-02-2014, 05:43 AM
Same looks good and does the job. My EWG harness is ticking all the boxes for me thus far !! No issues to report apart from upping my failsafe to 18
Chaddy74's Avatar
Car: M135i
Default 07-02-2014, 05:46 AM
i posted a photo a few pages ago if that helps
