(#576)
Default 12-08-2019, 08:29 PM
Originally Posted by cc61940542
log
Fuel pressure and knock look good, tried map2 for example? Might work out nicely here.
cc61940542 cc61940542 is offline
Car: 2018 rs3
Default 12-08-2019, 09:13 PM
map2 will add 3psi all range?
Default 12-08-2019, 09:25 PM
Yes, and map3 4psi across the board.
Car: 2018 rs3
Default 12-08-2019, 09:34 PM
FP_H, FP_l and trims are shown in the JB4 log, but I don’t know the conversion relationship between this and the actual value. Please tell me the scaling factors between these parameters and the actual value, especially trims. What are the upper and lower limits of trims? thank you very much
Default 12-08-2019, 09:51 PM
FP_H is 0-50 = 0-3000psi. FP_L isn't logging currently. It's an analog input that would need to be attached to the sensor.
Car: 2018 rs3
Default 12-09-2019, 12:11 AM
trims?MHD will have a range of + -34 on N54, but what about JB4? Of course on rs3,thx
theskunk's Avatar
theskunk theskunk is offline
Car: Audi RS3
Default 12-13-2019, 07:27 AM
Is there a way on the Mobile app (specifically the live digital gauge) to display both the actual boost vs the boost requested?
Daily Driver: 2018 RS3, Black Optics, Dynamic+, Driver Assist, STM resonator delete, STM intercooler, CTS Turbo Intake, EMD Springs/Swaybars, Girodisc Rotors, Carbotech pads, 034 goodies everywhere.
Tow-Vehicle: 2018 Jeep Grand Cherokee, Overland, 4x4 + Hemi
Past:
2000 3.8L Mustang - All bolt ons, 8.8 rear conversion
2007 Honda Accord - I had a moment of “sensible-ness”
2011 BMW 335D - Custom intake, JBD
2014 Audi S4 - Intake, Chipwerke, Couple of VCDS mods
Default 12-13-2019, 11:50 AM
Yes. Hold the gauge until the list pops up. Then you can click ECU psi for one (request) and boost (actual).
theskunk's Avatar
Car: Audi RS3
Default 12-13-2019, 03:25 PM
Thanks! Is it normal for the boost request to be a bit 'laggy' in comparison to the actual reading?
Past:
Default 12-13-2019, 04:04 PM
Should be pretty instant as you push the pedal more.
Car: 2018 rs3
Default 100-200km/h 6.45s - 12-15-2019, 08:17 AM
In terms of air intake, I just replaced a KN air filter, I feel like I have encountered a bottleneck. I have ordered the 4inch inlet of APR. When I install it, I will test it again. The current time is fixed at 6.45 s (full weight), and my log is attached.I noticed that WGDC100% @ 6500-7000rpm, stock turbo can only make 21-22psi. really want to touch 5.X with stock turbo,
PS: because my car is flashed, I did not install the BCM plug
Default 12-15-2019, 10:12 AM
I would suggest attaching BCM plug, it may help here!
theskunk's Avatar
Car: Audi RS3
Default 12-18-2019, 07:42 AM
Any status updates you guys can share wrt the no-boost issue?
Is there a way that we can turn the logging up to be more verbose to capture it with a bit more granularity? Now that it's cold out, I'm not sure what's happening but I hit it almost daily to the point that the car has zero boost until the ignition is cycled - no codes from JB4 nor VagCom.
Past:
cityazndan cityazndan is offline
Default 12-19-2019, 04:27 AM
Any updates on the no boost situation?
SOLD 2007 BMW 335i | 6AT | ZSP | ZPP | ZCW {Smurfin' before it was cool}
|JB4 G5 ISO|Cobb|S&B Filters|RB|Evolution Racewerks|Synapse|ar design|JetHot|Active Autowerke|Bastuck|
||Amuse Ericcson|M-Sport|M5 SMG Knob|V1 Yellow Stripe Steering Wheel||
SOLD 2009 BMW 335i | 6AT | ZSP |ZPP
|FBO, PS2, Meth and #spacegraybrigade|
OTW 2018 Audi RS3 |7DCT |Dynamic | Black Optics | Tech | RS Design
Default 12-19-2019, 06:48 AM
The logging is at the max resolution for the amount of parameters logged. The more you add the lower the res becomes.
We have some different enclosures coming in the next week to test.
2021 VW Golf 8 R
Car: 2018 rs3
Default 12-20-2019, 06:52 AM
Here is a log off a flashed one, who will be using the JB4 for fine tuning, logging, and running WMI. All of the JB4 maps are currently additive based. So he's adding a couple PSI over "stock" here.
Is this a stock turbo RS3? Wgdc was 100% when my car was redline, but I only saw 21.x psi
timmyzr1 timmyzr1 is offline
Car: RS3
Default 12-20-2019, 09:29 PM
Had me to list of no boost/boost drop then pick up!!! Today was cold(-20 C) so sometimes boost doesnt come up at all. Sometimes spool start pull hard, then drop off. running map 2 now on 91. I just bought the car, happy that JB4 was installed… now after reading this thread, im thinking of ripping the freaking thing off!!! RS3 2018 cts intake, iroz d p and mp
Car: RS3
Default 12-21-2019, 06:43 AM
Maybe cold weather have something to do with the aggravetion of the boost problem?
russ86 russ86 is offline
Car: Audi RS3
Default 12-21-2019, 07:50 PM
Unfortunately it's not the cooler weather. It's summer time in the southern hemisphere
I'm running a custom tune and have the JB4 in for logging with only the TMAP plugged in. I still experience the boost problem
Car: 2018 rs3
Default 12-22-2019, 06:30 AM
Yeah,even if it is only used for logs, there will be boost issues, there seems to be no effective way, currently it can only wait for JB
Car: RS3
Default 12-22-2019, 08:05 AM
Ill might have to take it off for the winter unfortunately!!! Ill wait to see if BMS come up with some kinds of solution, if not it will be permanant. Cant build something reliable with this now!
Default 12-22-2019, 04:39 PM
What happens in your trim if you attach the TMAP connector only to the MAP connection on the manifold? Both sensors have the same scaling so on map0 shouldn't matter. To see if the issue is TMAP signal related specifically.
Car: Audi RS3
Default 12-22-2019, 07:16 PM
I'll give that a go Terry and will let you know.
Car: Audi RS3
Default 12-22-2019, 09:59 PM
Just confirming plug the TMAP connector (JB4) side to the manifold. Don't worry about plugging the manifold RS3 harness to the JB4?
Default 12-23-2019, 04:25 AM
He means use the plug with all the wires on the intake manifold connection. The one with the brown dont connect at all.
2021 VW Golf 8 R
