(#551)
Bullitt1841's Avatar
Default 11-20-2019, 07:20 PM
What I've noticed is that I get it WAY more often when the weather is humid out. When the air is dry, boost response is spot on and I rarely experience the no boost condition.
Car: F06 N55 640i Gran Coupe
Default 11-27-2019, 04:02 AM
After re-wrapping (5layer) the bcm, extended the wiring into the cabin (below the passenger seat RHD) I canít trigger the no boost issue even when Iím on manual mode. For me is totally gone! Good luck to u guys.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 11-27-2019, 04:21 AM
Cut & joint the wiring.
tegxsi tegxsi is offline
Car: RS3
Default 11-27-2019, 09:15 AM
seems a bit extreme but if this works then it proves that better signal filtering or shielding is needed.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Default 11-28-2019, 01:01 PM
We don't expect anyone to do any of this. If you feel like being a hobbyist and experimenting go for it but its most likely these bags and relocation things will wind up being unnecessary. If we do find EMF is the cause then we'll need to solve it in the JB4 enclosure and with some additional board filtering.
Andy is a vendor and experimenting with different things on his own to collect data on the issue and sharing what he finds in real time.
Once we nail down what the issue is BMS will provide a solution free of charge to our customers. It's strange as some customers never have the issue while others have it frequently. We rarely have it on our development cars. Which to date has made it tricky to nail down a common cause.
Mkai0 Mkai0 is offline
Car: Audi RS3
Default 11-29-2019, 01:00 PM
I hope everything gets cleared up soon. I was hoping to not flash my ecu, but ended up going Stage 1 Unitronic on this particular platform with hopes of maybe stacking with a JB4 one day.
Car: Audi RS3
Default 11-29-2019, 01:14 PM
Terry, have you used E85 on your TTRS APR/JB4 setup, and if so how much Ethanol? Was wondering if I could maybe do the same one day.
Default 11-29-2019, 02:14 PM
Yes but it requires our AFR control wire to adjust the AFR as APR has it set too rich. But with that you can use any mix you want. I've been running straight at around 24psi.
Car: Audi RS3
Default 11-29-2019, 03:22 PM
Is the AFR control wire built into the JB4 unit, and when you say running straight, do you mean full E85?
Default 11-30-2019, 12:10 PM
Originally Posted by t-800
It's a bit disappointing that owners should have to go to these lengths to sort out this issue........
You do realize how difficult this is to troubleshoot, right? BMS even went as far as redesigning the board and asking their supplier(s) to remake additional boards to test. This is NOT cheap or quick.
This is a BETA product and users are here to help provide feedback. It's not required, but you knowingly purchased it as being a BETA tester.
Default 11-30-2019, 01:39 PM
It's build in to the latest rev2.2 board. Then there is an extra wire you plug in to the harness and posi-tap to the primary o2 sensor signal wire. This allows the JB4 to directly change the air/fuel ratio.
I've been using straight E85, but various mixtures can be used as well. I'm also equipped with a Fuel-IT flex fuel sensor kit so the JB4 is able to read the E85 mixture and scale the tuning as a function of it.
RSthree RSthree is offline
Car: Audi RS3
Default 11-30-2019, 04:03 PM
So this is effectively a flex fuel set up? So the jb4 already has an input for the fuel sensor?
Car: Audi RS3
Default 12-04-2019, 04:05 PM
Thanks Terry, looking forward to seeing more results of how this system works with various E85 mixtures. How much time did it take to install the Fuel-IT system?
Car: RS3
Default 12-05-2019, 09:17 AM
So will the stock tune + JB4 w/ fuel wire allow for straight E85? BEF needed?
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Default 12-05-2019, 09:37 AM
No, the o2 biasing is only useful for those who are also flashed. The flash tuners have a nasty habit of setting AFR so rich it bombs out the fuel pump with high boost and E85 mixtures.
Default 12-05-2019, 09:38 AM
The flex fuel kit is super easy, 10 min? All up top.
Car: Audi RS3
Default 12-05-2019, 11:09 AM
Thank you Terry. Iím looking forward to this setup accompanying my APR tune once the no boost issues are sorted.
cc61940542 cc61940542 is offline
Car: 2018 rs3
Default RS3 Flash+JB4 100-200km/h - 12-07-2019, 12:45 AM
2018 RS3
Mods:Flash+JB4;stock turbo;iroz intercooler;*********;kn air filter;snowperformance wmi;fuel E70
Exterior:sleeper
Car: 2018 rs3
Default 12-07-2019, 12:48 AM
Full weight
Default 12-07-2019, 12:52 AM
Which flash are you running?
Car: 2018 rs3
Default 12-07-2019, 01:02 AM
IE stage2
Default 12-07-2019, 10:46 AM
Post the CSV!
Car: 2018 rs3
Default 12-07-2019, 06:49 PM
Post the CSV!
log
Car: 2018 rs3
Default 12-08-2019, 07:09 PM
Post the CSV!
Can you share your log(CSV)) of APR E85?thanks~
Car: 2018 rs3
Default 12-08-2019, 07:23 PM
Originally Posted by theskunk
Had a new one happen yesterday - the car went into 'no boost' mode after a 'bobble' in 3rd. I assumed it had kicked me to map 8, however when I pulled up the app, I was still map 3. No amount of pressing and letting off nor gear change resolved it. I changed to map 2 with no change. I finally turned the car fully off and then back on and everything seemed to fix itself temporarily, however after that one issue I went back to having low/no boost almost every single launch. This morning I disconnected the JB4 and will leave it off until there is something else from the BMS team to report back on.
You are in the same situation as me,I just keep hoping that JB4 can be perfected as soon as possible
