Default JB4 Ford F150 Raptor & EcoBoost - 01-29-2018, 02:32 PM
http://burgertuning.com/ford_f150_ra...nce_tuner.html
BMS data cable hard wired directions Click here
JB4 Map Guide as of V3 firmware:
Map0: Fully disable JB4
Map1: +3.5psi peak over stock, default map, suitable for all fuels.
Map2: +3.5psi peak, less top end taper, more aggressive version of map1.
Map3: +4psi peak, suggested for 93 octane and/or modified trucks
Map4: Low boost VALET map
Map5: +6psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
Map7: +7psi peak, experimental map for unleaded race fuel. Factory fuel system likely can't keep up with this map on E30.
JB4 User Adjustment Settings:
Most settings do not need to be changed unless directed by BMS technical support to address a specific issue. But the following settings can be user adjusted:
Boost by gear: Enter amount of boost reduction in 1st, 2nd, or 3rd gear. Very useful for improving traction on RWD vehicles. We generally run 5psi in 1st, 1psi in 2nd, on our GT on stock tires to avoid wheel spin during launch mode. This reduces boost in 1st gear by 5psi, and reduces boost in 2nd gear by 1psi. You can reduce boost below factory levels as needed.
Map6 Boost: Allows you to enter a customized boost profile. You'll enter only peak boost over stock here, so 6.0 means add a maximum of 6psi over stock, at that RPM point. The JB4 will blend this request with pedal input, engine temperatures, etc, to provide a smooth mapping. Generally this is only used for advanced customers who are able to read their logs and looking to make a map less aggressive than our off the shelf maps. Note that setting RPM1500 to 10psi or higher will trigger map6 values to act as "absolute" targets rather than "additive" targets.
Boost Safety: Used to determine the maximum boost before the JB4 will disable itself. Boost must be sustained for at least one second.
Raptor JB4 Dyno Results: N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 Ford F150 Raptor EcoBoost
F150 2.7L Pure Turbo Dyno Results: N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 Ford F150 Raptor EcoBoost
How to update firmware:
For firmware updates we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
How the app works:
maxboost_R maxboost_R is offline
Car: 2011 E92 335xi
Default 01-29-2018, 07:51 PM
Hey Terry, any plans for the normal 3.5 ecoboost?
2011 AW E92 335i xDrive M Sport Fully Loaded - BMS N55 G5 ISO, Intake, FSB, BMS/CPE Charge Pipe and Trunk Mount Meth Kit | AR Design 4" Catl3ss ******** | BMW Performance Exhaust, Kidney Grills, Rear Diffuser, Carbon ZCP spoiler and Interior LED Lighting Kit | KW V1's | Dinan 15.8mm rear sway bar, Front Strut Tower Bars | Work VS-XX | 3M 15% Tint all around |
Default 01-29-2018, 08:39 PM
Old firmware notes for posterity
JB4_FORD_ECO_8:
1) Increased sensor sampling rate for smoother performance.
JB4_FORD_ECO_7:
1) Logical changes to address infrequent false alarm fault code on some models.
JB4_FORD_ECO_6:
1) Various changes to allow same firmware to be used across multiple Ford EcoBoost platforms.
2) Adjustments for vehicles equipped with back end flash maps. Email for details if running the JB4 in conjunction with a flash tune.
3) Added additional logging channels including high fuel pressure and timing pull (shown under ign avg).
JB4_F150_3:
1) Another adjustment to try to eliminate false alarm 04DB codes
2) Added VALET map4 which runs around 1/2 as much boost as stock. Fun for when you let "friends" borrow your Raptor.
JB4_F150_2:
1) Increased torque on map2
2) Back end change to increase analog channel sampling rates. Should not be noticeable to end user but may improve smoothness of idle and other aspects of JB4 operation.
3) Adjustment to CANbus logic to hopefully avoid false alarm 04DB code that a couple customers reported.
JB4_F150_1:
1) Adjusted map1 for more boost down low, less up top, to better match lower grade pump fuels like 91 octane.
2) Fixed IAT bug causing some vehicles not to datalog IAT correctly.
3) Added logic so that JB4 rainbow patch can be attached to the MAP sensor (towards the read), and the JB4 brown patch can be attached to the TMAP sensor (in the front). This is now the suggested installation and some users have reported smoother operation in this configuration.
FoShizzle's Avatar
FoShizzle FoShizzle is offline
Car: '11 335is DCT
Default 01-30-2018, 09:07 AM
This is so awesome Terry! Iíll be ordering a Raptor later this year and you were going to be my first call. Boltons are available, but it seems the tuning market for this engine is almost untouched. Canít wait to see what you can do!
TMR's Avatar
TMR TMR is offline
Car: E92 335i
Default 01-30-2018, 10:36 AM
Donít they run 16-18 stock? If you need a test truck, let me know.
Default 01-30-2018, 10:37 AM
We measured 15psi on Greg's but I'm sure boost is load based, so will go up or down depending on the weather.
allanC allanC is offline
Default 01-30-2018, 03:37 PM
Hey Terry, if you also get into the normal F-150 3.5L ecoboost I think you will probably gain a lot more business. They use the same engine in quite a few different platforms. But I would definitely be on board for JB for my truck. And I would be down to be a tester. I also work at a shop with a DynoJet linx system so if you need #'s I can crank them out for you. My vehicle is a:
2016 Ford F-150
3.5L Ecoboost
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 01-30-2018, 03:56 PM
Oh my... tow truck!
Default 01-31-2018, 09:44 AM
2016 Ford F-150
3.5L Ecoboost
Yes I'm 99% sure it will be compatible, so we'll have the same tuner for both 3.5L models. With the only change being on the software side.
Email me if you want to help test it out.
Car: 2011 E92 335xi
Default 01-31-2018, 09:44 PM
Terry, if you need more testers for normal 3.5 ecoboost let me know I would be very interested in helping out, I have a 2015 F150 3.5 ecoboost as well.
Default 01-31-2018, 10:14 PM
We've got a handful of systems either in use or on their way. Assuming all goes to plan we'll have the Stage1 BETA up on our site soon to expand the testing pool. The F150 platform at large has a lot more potential and interest than I expected.
Default 02-01-2018, 08:57 AM
you have been e-mailed sir. Thanks
Hippo Tim's Avatar
Hippo Tim Hippo Tim is offline
Car: 2008 335xi e92
Default 02-01-2018, 04:49 PM
It's gonna get real fun, real fast Big T!
2001 Corvette Z06
Performance*BTR stage 3 cam package*XS Power LTs and off road x-pipe*Vararam intake and power duct*Dyno tuned by Strictly Performance*Nitto 555r*450whp/408wtq*Best 1/4-11.3@122
2017 Ford F150
Performance*JB4*BCB e50 custom tune*QTP Resonator Delete with e-cutout*Best 1/4-12.7@108
Default 02-01-2018, 05:39 PM
A local customer got the 2.7L model EcoBoost also, can't wait to check that out.
Hippo Tim's Avatar
Car: 2008 335xi e92
Default 02-01-2018, 06:12 PM
I've heard they are a dark horse. Also think they are running a CGI cylinder block, so a little different from the rest of the EB line-up.
2001 Corvette Z06
2017 Ford F150
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 02-02-2018, 06:24 AM
Very nice! I’ve already flashed mine, but a large market for sure. Looking forward to watching the development.
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
'09 997.1 6MT: FBO, 65mm VTGs. 730 whp
'18 Nardo Gray RS3 APR stage 2, 10.72 @ 130
A418t81's Avatar
One tire fire
Car: E92 335, 6MT
Default 02-02-2018, 11:54 AM
I also meant to say, 15 psi peak sounds like he may be on the low octane maps. Is he running 91? It may be that the Cali 91 isn't sufficient for the maximum performance maps the factory ECU has. Mine on 93 is 14-15 psi rising to 17, which given normal temps is average with sufficient octane. A max of 15 psi suggests it's running on lower performance maps. I'd have him blend in 5 gallons or so of E85 and see what happens. +3 psi should get you right up to 20 psi high up in the rev range. These ECUs also have dynamic advance as well as retard ignition correction...on E30 and in the lower gears, I've seen it add 2-3 deg of timing.
'19 GT3 RS Weissach
Default 02-02-2018, 01:32 PM
Yes was running 91 octane. We should start getting a wider range of data in soon on them. I've heard it has built in flex fuel also which would be great.
A418t81's Avatar
One tire fire
Car: E92 335, 6MT
Default 02-04-2018, 02:42 PM
Hmm, I haven't seen the ethanol sensor anywhere. I wish the flash folks would figure out how to balance fuel delivery across the DI and PI during WOT so that higher concentrations of E could be used without crashing the high pressure pump. I've limped mine a few times at low rpm partial throttle, where it'll zip up to 20 psi at around 2k rpm and bottom the rail pressure out to 250 psi, haha. If I don't add any E85 it really doesn't drop too badly, but even E30 I have to semi-keep an eye on part throttle low rpm boost. I've told them they need to limit boost pressure and ride the edge of pump performance up to 2500 rpm or so, but they don't seem interested in doing that. Its good up to about 14 psi at super low engine rpm before any noticeable pressure deviation begins. This is about double the boost pressure the factory runs in this range, as opposed to nearly 3x with the MPT tune.
'19 GT3 RS Weissach
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 02-06-2018, 03:42 PM
You NEED to support the 17' Explorer 3.5L twin turbo. Like, you NEED to!
Syclone Syclone is offline
Car: 2008 E88 135i Convertiblev
Default 02-09-2018, 11:40 AM
I am up for testing on the 3.5L Ecoboost for the Taurus SHO and Ford Flex. I have both a 2011 SHO and a 2014 Flex - they both have the 3.5L ecoboost.
Lake Wylie, SC
2008 BMW 135i E88 Convertible
Blue/Black
Koni STR.T suspension, M3 Front suspension arms
JB4 Map 7, E85 Backend flash, Fuelit stage 2 fuel pump, Mechtech Intercooler, Raceland ***, NGK Sparkplugs, BMS DCi, Alpina Trans flash, BMS silicon inlets, BMS charge pipe.
Default 02-09-2018, 11:57 AM
I'm 99% sure it's fully compatible. If you have one contact me.
Car: 09 E92 SG
Default 02-09-2018, 12:03 PM
I do. And I did. Email is fmonteiro444@gmail
Default 02-09-2018, 02:19 PM
Since you have a flash tune already and modified tmap sensor not really the demographic we're looking for to test Stage1. But maybe down the road when we have a JB4.
Helltime Helltime is offline
Car: 09 135i 6mt
Default 02-12-2018, 03:08 PM
Terry, I enjoyed your products on my N54 135i, and 2015 GTI, I hope you end up supporting the 2.7EB at some point. That is my current ride and would be thrilled to have a JB set up for it!
2016 Jetta Sport 1.8T 5MT
2017 F150 2.7 Ecoboost
