(#1726)
busy busy is offline
Car: F30 EBII 335i
Default 05-14-2015, 02:53 PM
Originally Posted by endless_435
I noticed it on the 3.2 as well but definitely happened more on 3.3 since i updated last night.
I dint have any traction loss I know for a fact super dry pavement sticky tires, and you could feel the car hook up nicley it just shifted almost right away under load around 3 to 4k rpm ill note it happened also from 2nd to 3rd gear too.
I have had loss of traction a few times before and the car dint shift early any of the times.
weird I hope its not a major problem.
for me it always happens at ~5500RPM.
Default 05-14-2015, 03:40 PM
Originally Posted by e46m3to335i
I did a couple logs today on the new 3.3 map 1. To be honest it doesn't really seem all that quicker than stock. Bone stock 235i with 93 octane. Will be adding a ********* DP this weekend so hopefully map 2 will add some get up.
-Nick
Red is stock boost and blue is tuned boost. Should be a good bit quicker than stock... Map 2 will probably be more to your liking though.
Default 05-14-2015, 03:41 PM
Updated last night,
after a night of driving, while in auto sport mode car once in a while shifts gears way too early from first into second as im jamming on the throttle, ill do some logs later today maybe there's some correlation?
The JB4 can't effect shift behavior directly. Short shifting is the result of the DME perceiving wheel spin and shifting up to the next gear as a result. You should be shifting N55s around 5700rpm anyway for optimal acceleration. Sounds like it's doing you a favor.
endless_435's Avatar
endless_435 endless_435 is offline
Car: 435xi
Default 05-14-2015, 04:27 PM
Thanks Terry,
for me it was shifting earlier, but good to know its now a major issue.
Thanks very much!
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 05-14-2015, 10:34 PM
Got a quick map 2 log in this morning. 93 octane only. Seems to pull a tad harder than map 1 but not much according to the butt dyno. Maybe it's just placebo effect, who knows, lol.
boost82 boost82 is offline
Car: M235i
Default 05-15-2015, 03:01 AM
You're hitting 15lbs of boost which is nice
Babyjoe1973 Babyjoe1973 is offline
Car: 135i and M3 E30 Evo III
Send a message via Skype™ to Babyjoe1973
Default 05-15-2015, 05:17 AM
So, tested the 3.3 a little bit more! I got a lot of Drive Train Errors on the dash! Back to 3.2 no Problems! Seems there must be something wrong here!!l
Babyjoe
BMW M3 F80 ZCP
Car: 2015 F22 M235i
Default 05-15-2015, 05:57 AM
Attached is a second log of map 2.
Seems like I'm only hitting the 15-15.5 psi in 5th gear. Back when I had a FBO N54, the only gear that wouldn't hit target was 1st and sometimes 2nd.
I'm thinking that maybe the combination of the stock turbo and the shorter gears in the 8AT transmission just doesn't allow the turbo to load up enough to hit the targets. I could be wrong, maybe Terry could comment on this.
Not sure if it's a N55 JB4 User/Interface thing or not but the "Target" logging PID seems way low. Anybody know what's up with the target PID?
-Nick
Car: 2015 F22 M235i
Default 05-15-2015, 05:58 AM
Babyjoe
Torben,
Do you have the EWG specific board, Flex fuel wires, and EWG wires??
-Nick
Default 05-15-2015, 06:13 AM
Hi Nick,
yes the EWG wires and Flex fuel but not the EWG upgrade board. Only the normal one! Put JB4 to Map 0 everything works fine! Onyl in Map 1 and 2. With 3.0 and 3.2 no Problems!!!
Torben
BMW M3 F80 ZCP
Default 05-15-2015, 07:49 PM
Babyjoe
No known issues. So next time be sure to read the fault. Probably just a setting on your setup.
Default 05-15-2015, 07:51 PM
-Nick
I think I saw this same log in the support section. Which is where all logs should go. But looks basically on target to me. In lower gears you'll have less boost especially with additive maps like the new map 1 and map 2 because the DME has a lower target there & since duty cycle is being run by the DME it takes some time for EGT to get up high enough to allow the car to hit those higher targets.
Car: 2015 F22 M235i
Default 05-16-2015, 12:55 AM
Makes perfect sense Terry. Thanks for taking the time to explain it
BD_F22 BD_F22 is offline
Car: 2015 m235i xDrive
Default 05-16-2015, 06:10 AM
-Nick
Hmm thats weird.. My car is a 15' 235 8AT and I hit 15psi for a brief moment in 3rd gear
Car: 2015 F22 M235i
Default 05-16-2015, 08:25 AM
Yeah, it does seem a bit weird. I'm use to the way the older maps worked by targeting a set psi regardless of what the DME is targeting.
Car: 2015 F22 M235i
Default 05-16-2015, 08:33 AM
Not sure if I missed it somewhere or not but how is the BMS FSB wired when running a EWG board, FF, and EWG connectors?
Default 05-16-2015, 10:25 AM
It's in the EWG specific thread. But the blue wire goes to DB9#9 (data cable) instead of DB25#16 (JB4 main connector).
bigdeep1 bigdeep1 is offline
Car: 2011 535i (sport, prem 1,2)
Default 05-16-2015, 11:55 AM
I am not seeing the install guide for the BMS Stage 1 N55 install.
For the MAP sensor, should the brown or purple harness be connected?
The F30 instructions (only one I can find) says brown; however, the purple fits perfectly. Brown doesn't snap in as OEM.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 05-16-2015, 02:33 PM
On your F10? http://www.n54tech.com/forums/attach...7&d=1402085419
Rainbow is TMAP, Brown is MAP, Purple is MAF and unused
Mike Levy
Default 05-16-2015, 05:18 PM
You must have the wrong harness type then.
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 05-16-2015, 05:23 PM
Why the change to additive maps? Sorry if there was an explanation somewhere but I couldn't find any more info on the change other then what's in the first post.
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Default 05-16-2015, 09:24 PM
Thanks! Very helpful. I couldn't find this on the BMS guide site.
Terry, I believe I have the correct harness type (A) for my 2011 F10 n55. It is odd that the style of connector for my TMAP is A, but my MAP is B. The brown harness will not fit for my MAP. The purple harness does fit perfectly. Should I not install this? Oddly enough, I used this tune for a year before I removed it a few months ago for dealer work. I must have had the purple connected for the MAP before. No issues.
Unfortunately the instructions posted does not mention what color harness to use for the MAP. By elimination it would be brown because the purple was said to be unused.
Car: 2015 F22 M235i
Default 05-17-2015, 10:18 AM
Terry, just to confirm how the FSB should be wired for peeps that are running the EWG board, FF, and EWG wires.
Blue FSB wire to DB9 position #9
Orange FSB wire to DB25 position #3
Green FSB wire to solenoid ground wire
Black FSB wire to chassis ground / shock tower
Red FSB power wire to under hood 12V post
Red(thick) FSB to pump and solenoid power wires
Is this correct?
Default 05-19-2015, 08:29 AM
Feel free to post photos in the support section. You've mistaken your MAF for your MAP. The MAF uses a "type B" style connector but should not be touched as its not used for the JB4 installation. TMAP and MAP always use the same connector. Should be TypeA for a 2010.
Default 05-19-2015, 08:30 AM
Is this correct?
Sounds right to me. The FSB RED wire on the same side as the ground is the +12v. while the other one goes to the pump & solenoid.
