deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default Its not always a boost leak - 08-31-2014, 05:46 AM
I went a couple of months with a slow spool to 15 psi and a struggle to pull from 5k-7k rpm. Long story short I replaced all vacuum lines, boost solenoids, and removed the FMIC and charge pipes and reattached to ensure no leaks.
Problem remained poor slow boost only able to hit 13-15 psi, where before I could target 20 at 4500 rpm.
Next I started looking at turbos they also appeared fine we decided to just leave ********* DP's unattached to the remaining muffler, my buddy said it could be that the secondary cats were clogged. We took it for a test drive, wala instant boost car back to beast mode louder than **** but problem found. Secondary cats were clogged to hell, so I bought a Cobb exhaust that removes secondary cats car is back to running like a champ. A weight savings of easily 40-50lbs and way less restrictions.
Latest logs with a VD of the pictured pulls and how she is running with the new exhaust.
2011 335is DCT
Pure Stage 2 Hi-Flo Turbos | PSP outlets | RB Inlets | Wagner Evo 2 intercooler | Wagner Dpipes's | JB4 G5/MHD| Precision Raceworks Coils |PFS Bucketed Double shot LPFP | Phoenix Charge Pipe with Tial BOV | JB4 G5/MHD | BMS DCI's
RIP 2007 E90 335i
Doc Race 6266 Single Turbo | TFT Charge Pipe | JB4 G5/MHD | FuelIt stg 3 LPFP | Cpe/BMS PI | 100% E85 | DSS Axles | Cpe FMIC | Tial BOV
N54 World Record ET: 10.721 | Best MPH 130.92
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 08-31-2014, 08:37 AM
Damn bro, glad you figured it out. Did you take any pics of the clogged cats?
wtfmarine's Avatar
wtfmarine wtfmarine is offline
Car: 2007 BMW 335i
Default 08-31-2014, 08:56 AM
I'm having similar issues and know I don't have a boost leak. I need to do the samething as you.
07 335i sleeper - PT5858 single turbo - stock exhaust - stock wheels
deltalima0's Avatar
Car: 07 BMW 335
Default 08-31-2014, 08:59 AM
No Britton is going to cut the cats out though and use the pipes to do a ***** less setup.
2011 335is DCT
RIP 2007 E90 335i
deltalima0's Avatar
Car: 07 BMW 335
Default 08-31-2014, 09:06 AM
I guess the main keys here were that I never got codes for a boost leak and it would slow spool to 13-15 psi. The main thing is at 5k to 7k it pulled very slowly just a long struggle to get there.
If you want to test just undo the *** from the exhaust. It will be loud as he'll but all restrictions gone if you hit boost secondary cats are clogged.
2011 335is DCT
RIP 2007 E90 335i
kboretti's Avatar
kboretti kboretti is offline
Default 08-31-2014, 09:23 AM
what's your mods? 514 HP is pretty good. Is it the meth doing that?
2008 335i JB4 30% E85
2006 325i Stock
deltalima0's Avatar
Car: 07 BMW 335
Default 08-31-2014, 09:31 AM
Mods in sig I am FBO, stock turbos, fmic, ER charge pipe Tial BOV, HFS meth kit, E85/93 70/30 blend, ***** less ***, cobb exhaust ,backend flash. Pushing the stock turbos to 20 psi at 4500 rpm and tapering to 16 at 7k. So I am pushing hard really need to keep maintenance and log when pushing like this.
2011 335is DCT
RIP 2007 E90 335i
IBND335i's Avatar
IBND335i IBND335i is offline
Car: 2007 BMW 335i coupe
Default 08-31-2014, 01:07 PM
nice! what fmic are you running?
deltalima0's Avatar
Car: 07 BMW 335
Default 08-31-2014, 02:38 PM
Cpe FMIC.
2011 335is DCT
RIP 2007 E90 335i
Miller335 Miller335 is offline
Car: 2007 E92
Default 09-01-2014, 02:44 AM
You running map3 around 75 adder or map 6 custom settings?
scotte30m3 scotte30m3 is offline
Car: 07 335i sedan
Default 09-01-2014, 04:12 AM
Had the Sam problem as you... Only mine was low- slow boost with misfires
FBO (-meth), JB4 and RBs.
deltalima0's Avatar
Car: 07 BMW 335
Default 09-01-2014, 04:52 AM
Custom map 6 targeting 20 psi at 4500 rpm.
2011 335is DCT
RIP 2007 E90 335i
IBND335i's Avatar
Default 09-01-2014, 06:35 AM
Nice
Car: 335i e90
Default 09-02-2014, 09:48 AM
Clogged cats can be a hard to diagnose and incredibly annoying problem. I had a daily years ago and could not for the life of me understand why it was such a dog under load. Pulled the exhaust one day after I exhausted (LOL) all other options and it was hilarious, the car was an animal. A trip around the block and I thought it was a Porsche.
I ended up breaking out the cats and all was well, it was Indiana so as long as it had a vin, or something like a vin, you could drive it.
'07 e90
mrwoodwork mrwoodwork is offline
Default 09-02-2014, 12:14 PM
Your post couldn't come and a more perfect time, was ready to tear my car apart this weekend because of same issue, undid the exhaust from the DP's and sure enough, there it was! Thanks for the post and keeping us informed.
2007 BMW e92 335i Sport Package - JB4-G5-ISO - BMS Down pipes - BMS dci - BMS Trunk Meth kit - Cpe Charge Pipe w/ Tial BOV - BMS Cowl Filters - Walbro 450 LPFP - VRSPEED Intercooler - Turbo Back Exhaust - - Billet Wheel RB's w/ Clipped Turbine - 3.5 Bar Sensor - Wavetrac LSD - MHD BMS E85 Flash
JETmn JETmn is offline
Car: 2011 335xi
Default 09-02-2014, 12:43 PM
What kind of miles do you guys have on where you are seeing this?
IBND335i's Avatar
Default 09-02-2014, 12:52 PM
^This lol
boricua114 boricua114 is offline
Car: 07 335i Jb4, Dp, Dci
Default 09-02-2014, 04:27 PM
wow thanks i am having the same issue. i was also about to tear apart my intercooler setup
deltalima0's Avatar
Car: 07 BMW 335
Default 09-02-2014, 07:25 PM
Good to hear, glad this post helped you.
2011 335is DCT
RIP 2007 E90 335i
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 09-05-2014, 11:20 AM
I think the primary reason for clogged cats is either burning oil (from worn rings/valve seals/etc) - or running too rich, which will clog the *** elements too.
So YMMV depending on the vehicle, condition, mods, etc.
BoostHaus's Avatar
BoostHaus BoostHaus is offline
Default 09-05-2014, 04:17 PM
Good stuff! Glad you were able to get your car sorted out OP and I'm sure this info will help others. Probably the most valid reason to upgrade to an aftermarket exhaust that I've ever seen.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 09-06-2014, 07:22 PM
Thanks for sharing and great to know!!
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 09-05-2015, 08:45 PM
This is promising. My spool had been as slow as a turtle and i have been getting *** codes off and on. Will do the test by removing the exhaust. Will update. Thanks.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 10-07-2015, 11:11 AM
^updates ?
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 10-09-2015, 03:53 PM
Plugged cats are an extremely common problem when people run aggressive tuning, fueling through cats. We just had a Stage 2+ customer stuck at 550WHP, not matter what he did, finally pulled cats, problem fixed. Glad you found your problem!
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
