Default F30 EWG AFR Control - 08-22-2014, 03:43 PM
Been poking around on AFR control for the F30 electronic wastegate cars and finally made some progress. We can now dial in basically any air/fuel ratio we want. There are only two catches. The first is the richer the air/fuel ratio the more fuel is actually used... Placing an extra strain on the both the fuel pump and fuel trim ceilings. The second catch is the JB4 logs which read off the factory wideband still reflect the OEM air/fuel targets and not the richer targets. The second issue I can fix on the software side rather easily. The first has some implications for those who want to run larger turbos, E85, etc.
I spent a few hours on the dyno working up AFR tables and was fairly pleased with the results. The AFR altering effect is shown as "fuel enrichment" in these JB4 logs. The higher the number the most of an alteration the JB4 is making to the ratio.
As expected, enriching the AFR does not really add more power, reduce knock, or smooth out the curves, but it may reduce EGT (more testing required), and gets the F30 EWG tuning closer the general 12.5:1 "comfort zone" we've all been working within for the last few years.
Note I did some runs on map 7 just for the hell of it but without straight race gas picked up some knock. Also note for the map 7 runs I also left the AFR probe in the flapper side of the exhaust so it cut off the reading at low RPM before the flapper opens. Still, an interesting data point...
Lots of additional development to go. Including the best way for customers to implement this new control. Technically it can be done with a single wire and posi-tap (no new connector required) but I'm going to weigh the options as we continue development. I've become a bit disgusted with how cumbersome the F30 wiring harness has become with the various add-on patches so we'll probably be making some changes there soon. Maybe doing a new harness with every possible connector on it to clean it all up. I'll keep you guys apprised of any work on that front as well.
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default 08-22-2014, 04:21 PM
This is a massive Breakthrough T !! Well done !!
M135I ER Down-pipe & charge pipe ,Milltek full system,Wagner Performance Intercooler AFE Stage 2 Intake Pure stage 1 Turbo & Quaife LSD
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 08-22-2014, 05:52 PM
Great work! This will make a lot of people happy. I'm still hoping a free flash utility is released for the early pneumatic cars so I can fix AFRs without buying a Cobb.
Default 08-22-2014, 07:10 PM
The only way free software will ever come out is if Shiv decides to sell software, and his haters get together again, to develop it.
loesch's Avatar
Default 08-22-2014, 07:19 PM
If that ever happens I want to help.
Car: BMW 320i
Default 08-22-2014, 07:34 PM
Wow, that's awesome Terry!
How could this affect the 320?
Default 08-22-2014, 10:44 PM
We used this method to enrich our 320i test car during development. But it has a lower fuel trim ceiling due to the low factory boost target. Once we went to E85 we determined map 5 on the E40 mix was a good middle ground. I'm sure we'll revisit it at some point though. I've been working on the N20 EWG stuff with a few BETA testers as time permits...
4rose's Avatar
4rose 4rose is offline
Car: M135i
Default 08-23-2014, 04:51 AM
Well done terry....
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 08-23-2014, 07:27 PM
Ahhhh, awesome! Any luck with such function on n55?
Dietcoke Dietcoke is offline
Car: 08 135i
Default 08-23-2014, 08:29 PM
12:1 is awful rich for a DI engine
08' 135i - Cobb Custom E70, FBO, suspension stuff.
(OLD) 11 Camaro SS - 10.20@135 naturally aspirated @630rwhp.
Default 08-23-2014, 08:31 PM
It's just one of many variables. With the N55 at around 400whp I like the 13.5:1 midrange down to 12.4:1 up top range.
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Default 08-23-2014, 11:59 PM
Awesome results, 400whp!, with such minimal mods and cost
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 08-24-2014, 05:28 AM
What mods are on the dyno'd car? Those numbers are with a PURE turbo upgrade?
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Default 08-24-2014, 09:34 AM
Mods are in the first post. At lower boost levels the turbo is similar to stock, maybe a 10hp advantage. It's at higher boost levels and higher RPM that it would start to help more. It's basically a compressor wheel change. Nothing major.
kooleung kooleung is offline
Car: F30
Default 11-06-2014, 08:18 AM
Hi Terry, any new breakthrough? Should we expect a product launch on this soon?
nongy85 nongy85 is offline
Car: 2012 F30 320i
Default 11-26-2015, 06:58 AM
Terry,
I understand this is for the N54 EWG engines?
Would you be able to achieve this on the N20 EWG engines as well? That would probably open up higher boost capabilities (lower chance of knocking) on the 320i's?
Any chance that this could be done on the PWG models as well for the N20 320i's?
F30 320i Alpine White 8AT
- GSR Technik Stage 2 ECU Flash
- JB4 Map 1 @ 23psi max boost
- ER C@tless DP
- Simota Carbon Fibre Air Intake
- Mach5 Dual Exit Valvetronic Performance Exhaust
- Mach5 Aluminium Charge Pipes
