Car: 2007 BMW E90 335i
Default Menu 11 Default? - 08-07-2014, 12:46 PM
Anyone know the default value for Menu 11 (fuel open loop)? I was messing around with Menus 10 and 12 and accidentally moved Menu 11.
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 08-07-2014, 12:56 PM
Default is 80. Keep it mind it's x2 on the dash so move it to 4k rpm position. FOL autolearns so you may see it move up or down afterwards.
|2007 E92 SGM 335i|
Cobbv3 BMS DCI & OCC VRSF *** & FMIC E85 Custom Backend & Alpina TCU flash ER CP RB PCV+Cap
Walbro 255 Rohana RC5 19s Nittos 555 245/275 Cyba Scoops LUX V3 M3 Cowl ST Coils LCI Tails
Default 08-07-2014, 01:16 PM
Hmm, I just pulled up a screenshot I took when I was last connected to the JB4 and it shows 76 for Fuel Open Loop.
I bought this used from another person and have been in Map 1 the entire time. I am stock other than the JB4, 91 octane. Should I put it back to 76 or go with 80?
Car: 2007 335i E92
Default 08-07-2014, 02:08 PM
Just go with 80 and then check it later. It will change anyway adapting to your needs.
Default 08-07-2014, 03:28 PM
Does it adapt in Map 1, or only in Map 5?
Car: 2007 335i E92
Default 08-07-2014, 03:45 PM
All maps
|2007 E92 SGM 335i|
