(#926)
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default 05-29-2014, 08:23 AM
Well from the instructions there is only one value to change in the settings.Firmware loaded fine and completed and jb4 restarted and tested out good.Out of curiosity was cold start tested ? i might just wait for the harness before mucking around again. im happy with my current state of tune on 8.6 production firmware.
You probably just loaded something wrong or entered an incorrect setting somewhere. Without an EWG connector installed and without the blue pneumatic patch installed there is very little difference in the overall function of the firmware. We've run the EWG firmware on several cars without the adapter and it runs like normal.
M135I ER Down-pipe & charge pipe ,Milltek full system,Wagner Performance Intercooler AFE Stage 2 Intake Pure stage 1 Turbo & Quaife LSD
Chaddy74's Avatar
Car: M135i
Default 05-29-2014, 08:34 PM
Load firmware ...Confirm set PID to 12 OL to 50 for FF wires didn't need to disconnect battery due not installing the harness ? Anything else ? Also like to confirm that the EWG firmware is good for E30
Default 05-29-2014, 09:18 PM
PID setting won't matter, FF should be set to 50 when FF wires are installed, for any version of the firmware.
The EWG cars don't always tolerate E85. Don't be surprised if yours does not.
Chaddy74's Avatar
Car: M135i
Default 05-29-2014, 09:26 PM
Thanks Terry ... Ok.... But on the 8.6 version of the firmware my car is happy and has been running on e85 mix for a week. If its happy on 8.6 Firmware it would be safe to say that it should be happy on the EWG firmware ?
Default 05-30-2014, 04:24 PM
Here's a video showing how to avoid the startup code bug with the EWG harness in place.
Chaddy74's Avatar
Car: M135i
Default 05-30-2014, 04:39 PM
Thanks for the video Terry , Thats a great work around and simple solution to the problem in the interim !! Might be time for an EWG harness
Default 05-30-2014, 04:41 PM
It's been working for me hopefully others can test and verify its a good work around! The startup code is somewhat complicated but I'm still digging through it to find the culprit.
Hellraiserharris's Avatar
Hellraiserharris Hellraiserharris is offline
Car: 14' 435i
Default 05-31-2014, 07:39 AM
Originally Posted by Chaddy74
well if he didnt buy brand new your asking for trouble. that said i purchased brand new and it didnt even have the latest firmware :-( so who knows ..... need laptop and cable.
If you don't own a laptop. Get one of the 3rd party interfaces. you can do firmwares, change maps, logs and hell just about anything. I use the Android one. Works great.
14' 435i. M-Sport, JB4 Stage 2, BMS Intake, more to come
Jschappert1 Jschappert1 is offline
Car: m235i
Default 05-31-2014, 10:24 AM
terry,
will map 5 be finished by the next firmware update?
2014 M235i AT
JB4 Stage 2
Intake
35% e85
Default 05-31-2014, 10:35 AM
Probably. Working on it now.
Alpine435i Alpine435i is offline
Car: 435i
Default 05-31-2014, 01:21 PM
Nice. I do this anyway.
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 05-31-2014, 03:45 PM
I haven't had any start up code issues.
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Default 05-31-2014, 03:58 PM
Are you comfort access?
MarinoB's Avatar
Car: E92 335i
Default 05-31-2014, 04:26 PM
No
Chaddy74's Avatar
Car: M135i
Default 05-31-2014, 04:40 PM
Terry Im not sure if this helps you with the R&D process but i would get drivetrain malfunction error everytime after a negative battery disconnect.... Currently im not one of the EWG testers.
It wasn't until the other day when i removed the P3 from the OBD11 port that i realised that i didn't get the fault when disconnecting the battery. So in Short with something plugged into the OBD11 port for example P3 negative side of battery remove and attach I can recreate the error every time.
MarinoB's Avatar
Car: E92 335i
Default 05-31-2014, 06:55 PM
I had a drivetrain malfunction first time I took it out for a drive after install. Restarted the car and haven't had one since. I've had it installed a few weeks running map 2.
Chaddy74's Avatar
Car: M135i
Thumbs up 06-01-2014, 01:51 AM
Sounds Promising
khujo khujo is offline
Car: F10 530d
Default 06-01-2014, 02:25 PM
Where can I get this EWG Harness?
Reggie LeDoux Reggie LeDoux is offline
Car: BMW M135i
Default 06-01-2014, 03:51 PM
Can I ask what might be a dumb question? I live in the UK and have an M135i with EWG, and a JB4.
Without wastegate control, how can the JB4 actually provide more power on an EWG car?
I understand you may be able to vary ignition timing and A/F ratios to provide a bit more power. But if you don't have wastegate control how can you run more boost, which is what really provides the extra power/torque?
Once EWG is released and I get the new harness, how much more power and torque can I expect compared to the current Map 1?
JustinCredibleM's Avatar
JustinCredibleM JustinCredibleM is offline
Car: M235i
Default 06-01-2014, 07:24 PM
You can still reach higher boost levels, so you will still make more power, but without the EWG harness, you are limited to around 3-4psi over stock. I have a M235 and I did make more power on map 2 and map 7 without the harness.
Default 06-01-2014, 08:15 PM
The JB4 without the electronic EWG harness has limited duty cycle control, the EWG harness addition gives it a wider range of control. You can make 3-5psi over stock with the JB4 on EWG cars without the harness.
Car: BMW M135i
Default 06-02-2014, 02:25 AM
Thanks guys. That clears things up nicely.
ghostchili ghostchili is offline
Car: 2014 335xi
Default 06-02-2014, 07:18 AM
Terry, Is the E85 issue being worked on? I really want to unleash this thing!
brazil m135's Avatar
brazil m135 brazil m135 is offline
Car: M135i
Default 06-02-2014, 09:04 AM
Terry, all cars running FF wires have to set OL at 50 even if its not using E85 mix? (In my case I use race gas).
Tks
2014 Estoril Blue Bmw M135i - 8 AT - N55 EWG - Mods:Jb4 - EWG harness - FF wires, ER Charge Pipe, AfePower Momentum PRO 5R Intake System, H2Racing 3.5" CTless Down Pipe, H2Racing 3" full SS Exhaust w/o mufflers, Wagner FMIC, BMS meth kit 100%, H&R springs, RSV Forged 19" wheels. Now with PURE STG2 and PI
Car: M235i
Default 06-02-2014, 11:14 AM
What issue? I run an E35 mix and no problems so far.
