(#726)
mikew2069 mikew2069 is offline
Car: F30 335
Default 04-16-2014, 05:01 AM
Originally Posted by mikew2069
I'll try my best to get some logs today.
FYI to all those interested - I did 3rd gear pulls and a 40-110 pull yesterday and sent the logs to Terry. Everything looks good. I'm pretty much FBO w/ 93 octane but no meth. I need to get a little e85 next week and see how that effects boost...
Force[FED]'s Avatar
Force[FED] Force[FED] is offline
Car: '08 535i 6AT
Default 04-16-2014, 06:44 AM
Terry, since I believe the F30 and the F10 (such as my '11 535i) share the same JB4 firmware now, I would be willing to give this a try and capture some logs? I just want to be sure this firmware is compatible with my F10. I have been waiting for a firmware with a autotune!
My 535i is fully stock, runs 93 octane exclusively.
Kev
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 04-16-2014, 03:19 PM
Originally Posted by M-terkait
thought it was my car i do the same thing
Same here. Same color and everything. Except I stuffed it between the fender and A pillar gap and leave mine in permanently. It's tight but it does fit if you try hard enough!
2011 335is JB4- Gone
2013 F30 335i M-Sport JB4
CamNyc CamNyc is offline
Car: '13 f30 N55
Default 04-16-2014, 09:50 PM
Terry, for the EWG n55's are you testing cars equipped with both the 3in and 4in turbo outlets?
TheInfamousDrew's Avatar
TheInfamousDrew TheInfamousDrew is offline
Veteran Tuner
Car: F30 335i xDrive ///M Sport
Default 04-17-2014, 03:25 AM
Still waiting to get my car back from the dealer.....
I have all these parts just sitting here waiting to be installed.
Turn on. Tune in. Drop out.
IG: @Atomic.Raptr
Car: F06 N55 640i Gran Coupe
Default 04-17-2014, 03:58 AM
Hi Terry, I have F06 640i N55 FBO, Meth & Pure Turbo Stage 1. I don't mind if you need me to try out.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Veteran Tuner
Default 04-18-2014, 02:54 AM
Lets get some more reviews!
I just installed my dp, intake and the new firmware last night. I only drove it for about 15 mins and loved it. More logs coming today.
IG: @Atomic.Raptr
Default 04-18-2014, 08:48 AM
Not looking for reviews. Just data and any bugs to be emailed in. Thx.
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 04-18-2014, 12:22 PM
After ordering email us and we can ensure its properly setup for the N20.
I want to know if it's compatible because I live in Egypt & I can't make test but only logging if it helps..
John told me it might not be compatible as map 3 is disabled for now so I am a bit confused if I should buy it or not as N20 is an option when buying the Methanol Injection.
Car: Bmw 328i F30
Default 04-19-2014, 11:26 AM
If it's compatible with N20 (328i) I would willingly give you logs as you need
montgom626 montgom626 is offline
Car: 2013 BMW 335i xDrive
Default Why not just use Map 5? - 04-19-2014, 05:22 PM
Why not just use Map 5: Autotuning. Adjusts boost curve from 11psi peak to 16psi peak based on octane, mods, climate, etc.??
seems like the best choice among all the MAPS with N55 JB4.
I am a noobie, so I may have missed the answer.
montgom626
ballinsoldier's Avatar
ballinsoldier ballinsoldier is offline
Car: F30 335i
Default 04-19-2014, 08:46 PM
montgom626
Read the first post. Map 5 is still under development. Although, it looks like it should be ready soon with a software update.
Default 04-20-2014, 11:28 AM
Thanks you, I just completely missed the post on MAP 5.
Montgom626
Sanesh21's Avatar
Sanesh21 Sanesh21 is offline
Car: 2013 F21 M135i MT
Default 04-21-2014, 11:07 AM
logs emailed to terry, map 5 feels very good.
2013 F21 M135i 6MT
JB4 / PWG / BMS intake / BMS meth kit / FSB / ER CP / Down Pipe / VTT stg1 / Pure inlet / GFB DV+ / AFE air scoop / N20 Tmap / Rev3 Connect / M performance exhaust / ACS springs / H&R Trak spacers / M Performance V2 steering
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 04-22-2014, 11:36 AM
Any closer to a release for N55's?
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
AngeloF10 AngeloF10 is offline
Car: '13 535i xDrive M-Sport
Default 04-22-2014, 06:45 PM
when I try to download the .hex file for the firmware, it saves as attachment.php. is there something wrong with the file posted for download?
I just received and installed my JB4. should I expect the most recent firmware to already be installed? What Firmware and Interface Version should I see in the interface?
Default 04-22-2014, 08:15 PM
8/6 is the latest production firmware and preloaded.
Chaddy74's Avatar
Chaddy74 Chaddy74 is offline
Car: M135i
Default Firmware - 04-23-2014, 01:41 AM
Terry Chris Chadwick speaking - I received my second JB4 stage 2 this morning and it was not running the latest firmware ! I had to update in order for the steering wheel controls to work !! i could connect and see the box via the laptop , but until i downloaded the latest firmware in this post it wouldn't play ball. Out of two boxes i have purchased one had the latest firmware and one didnt. Cheers
Default 04-23-2014, 08:26 AM
Any reason why when I download the .hex file it is savinf down as attachment.php? am I doing something wrong?
never mind. looks like it was fixed
tibookM3 tibookM3 is offline
Car: E92 M3, F32 435Ms
Default 04-23-2014, 08:37 AM
Just wanted to throw my .02 in as well, anxiously waiting for the EWG control. I like my stage 1.5 but want to see what this stage 2 really intended to be:-)
Default 04-23-2014, 08:54 AM
Working on it daily. Plenty of work to go but starting to see the light at the end of the tunnel.
Chaddy74's Avatar
Car: M135i
Default Map 5 EWG - 04-23-2014, 12:20 PM
Hi Terry , how far away is map 5 for the EWG cars like the new m135i and m235i ?
BimmerFan BimmerFan is offline
Car: 2014 335i M-Sport
Default 04-23-2014, 02:33 PM
Keep up the good work Terry. I am watching this thread like a Hawk:
Me
1. Arrive at work
2. Log into work station
3. Go fetch morning coffee
4. Check account balance
5. log into N54Tech for updates
6. Now check e-mails and really start work..lol
Vic
Rollinglower42's Avatar
Rollinglower42 Rollinglower42 is offline
Car: 2012 BMW 335I F30
Default 04-23-2014, 02:46 PM
Any updates on Map 5, when it might be ready and released for all to use?
