Default 12-21-2015, 11:17 AM
Originally Posted by marcoac14
Hi George,
Is this compatible with the new A3 1.8T (MQB)? The car is euro spec but exported to Brazil and I'm not sure if there's any software changes to cope with our fuel or whatever.
The unit is compatible. Globally we lower the boost to 4.0. With the ethanol in your 87 and 95 you could use more boost due to the ethanol so if you get the unit be sure to get the cable so we can assist in optimising it.
Malte@CFD Malte@CFD is offline
Car: BMW M4 F82
Default 03-18-2016, 06:54 AM
Installed JB1 on our GTI MK7 (DP, 3" Exhaust, Shell Vpower 100 Oct) today.
283 whp / 444 wtq
Default 03-18-2016, 07:40 AM
283 whp / 444 wtq
Great result.
Mike@N54Tuning.com Mike@N54Tuning.com is offline
Car: 07-335i
Default 03-22-2016, 08:31 AM
We just got a large shipment of these in and already all shipped out!! Hot sellers for sure!
Mike
www.n54tuning.com
Default 04-24-2016, 07:27 AM
Two time slips for users that cropped up on the other forum showing great exit speeds which could translate to good time with traction..
Manual with DP, JB1 Map 1 5.0, stock tires
DSG with only Injen intake and JB1 Map 1 5.0, stock tires
Default 05-25-2016, 02:10 PM
Nice result with a manual GTI with JB1 and DP only running 13.1 on drag radials with no warm up allowed. Map 1 5.0 was used.
Default 06-24-2016, 02:17 PM
JB1 Golf GTI with ********, intake and around 100oct. Car made 314whp and 360ft lb, base dyno run is 242whp with map 0 and the high octane. Car was custom tuned by one of our dealers using map 6.
Default 07-29-2016, 03:00 PM
Some A3 2.0T loving.
Default 09-26-2016, 04:12 PM
We had a manual user dip into the 12's this weekend running a 12.9@109mph
Mods are JB1, DP and our meth kit running on Hoosier Radials. Car was full weight on stock suspension.
The stock clutch battled with the traction so the use of the Hoosiers turned out to be counter productive but the exits give a good idea of the power produced.
Default 10-11-2016, 05:41 AM
A user posted his dyno sheet on a another forum.
Dyno car with JB1 map1 @ 5.4. Just JB1, aFe panel filter and CTS DP on CA 91oct. Hood was closed on all runs and 90 degrees in the shop. 3rd gear.
The boost is relatively high for 91 octane so the torque has been cut by the ECU by around 40ft lbs, you can see on two of the runs the graph early on shows a adaption occurring. Good results nevertheless with a table top power peak.
Default 11-12-2016, 12:10 PM
Some nice results by David on his GTI on a heart breaker Mustang dyno. Mods are on the dyno sheet. They ran the car in fourth so it cut the gains short by running into the limiter.
Turbofrenetic Turbofrenetic is offline
Car: Octavia RS
Default 12-02-2016, 11:37 AM
If i had skoda rs with golf r turbo, what kind of jb1 i need?
Default 12-02-2016, 01:01 PM
We are releasing the JB4 this month that will be able to tune for the larger turbo on your Skoda.
Car: Octavia RS
Default 05-10-2018, 12:09 PM
Will it work with Audi A4 b8.5?
Default 05-10-2018, 07:48 PM
Not on the B8.5.
Car: Octavia RS
Default 05-11-2018, 02:55 AM
Not on the B8.5.
No chance to make it work? Same engine 220hp
Default 05-11-2018, 04:46 AM
Can you email me a picture of your engine with a general over view and I can see. There are some A4, 5 Quattro derivatives that the unit will work on.
You can email that through to george@burgertuning.com .
Frank Reynolds Frank Reynolds is offline
Car: MK7 GTI
Default 01-20-2019, 02:24 PM
I removed my JB1 yesterday, decided to scan the car today (no CEL) just to check it out since the hiccup issues I’m having do not seem to be related to the JB1 as some mk7 members suggested.
Are these codes normal after removing the JB1?
codes:
P011300 - Intake Air Temperature Sensor 1 Bank 1 Circuit High
Intermittent
P019000 - Fuel Rail Pressure Sensor "A" Circuit
Intermittent
P010600 - Manifold Abs.Pressure or Bar.Pressure Range/Performance
Intermittent
P010800 - Manifold Abs.Pressure or Bar.Pressure High Input
Intermittent
P023800 - Turbocharger Boost Sensor (A) Circ. High Input
Intermittent
Default 01-21-2019, 05:48 AM
Originally Posted by Frank Reynolds
I removed my JB1 yesterday, decided to scan the car today (no CEL) just to check it out since the hiccup issues Iím having do not seem to be related to the JB1 as some mk7 members suggested.
codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
If you removed it with the battery still connected without the ECU going to sleep it is possible these can be caused by the JB removal as that is where the unit connects too.
If you feeling hesitations in the higher gears its typical if the boost is set to high.
Brandon-Audi-S3-8V Brandon-Audi-S3-8V is offline
Car: Audi S3 2016
Default Mapping - 11-17-2019, 08:44 AM
Some nice gains from this JB1 user. Car is stock with JB1, map 1 +5.0psi on 91. Shows a 45whp gain.
Hi George and everyone. Iím new to this JB4 and forum. I just bought one with Bluetooth and need to install it into my S3.
How would I go about it asking u for help in tuning map 6 with my modifications on my car. Iíve already emailed u just waiting for a reply😊. Canít wait to install the JB4😄
Default 11-17-2019, 08:59 AM
This is the JB1 thread Replied to your email.
