may555 may555 is offline
Car: bmw f20 m135i
Default log map5 and map2 - 05-07-2021, 11:00 PM
hi
can someone look my log and tell me why in 4th gear my boost can't pass over 11?
the first run is on map5 and all the rest on map2
but on the map2/5 4th gear never pass 11psi
my it's a bmw f20 m135i setup:intercooler wagner evo1, catback m performance, charge pipe, boost pipe forge, and bmc filter
thanks
435gc 435gc is offline
Default 05-08-2021, 10:39 AM
Your duty cycle settings are messed up. Its preventing your wastegate from closing enough to build boost.
Set your WG duty cycle setting to 50 across the board and re log.
Car: bmw f20 m135i
Default 05-08-2021, 12:31 PM
how can I set into map 2/5?
I only have jb4 mobile apply
Default 05-08-2021, 12:38 PM
Go into settings. Go to advanced. Go into the user adjustment menu. Set all the duty bias values to 50. Press save.
Car: bmw f20 m135i
Default 05-08-2021, 01:16 PM
ok thanks, i will try it next time
user adjustment it's not only for map6?
Default 05-08-2021, 03:22 PM
Nope.
The boost settings in the user adjustment menu is for map 6 only, but everything else is carried across all maps.
Car: bmw f20 m135i
Default 05-08-2021, 04:50 PM
ok thanks for the info
Car: bmw f20 m135i
Default 05-09-2021, 02:47 AM
I try as you tell me with 50 on duty bias on map 5
the last 4 run I put 60 since 5000tr
Default 05-09-2021, 09:14 AM
Looks like.your hitting boost a little better. Id raise your FF up to 80 to speed up the wg learning and you should be good.
What fuel are you running?
Car: bmw f20 m135i
Default 05-09-2021, 09:31 AM
i'm from france i'm running in ron98
Car: bmw f20 m135i
Default 05-09-2021, 10:11 AM
my last log with ff 80
Steve @ BMS/Fuel-It! Steve @ BMS/Fuel-It! is online now
Default 05-10-2021, 11:25 AM
Still some underboost...bump FF up to 100.
Car: bmw f20 m135i
Default 05-12-2021, 07:07 AM
last log with ff up to 100
Default 05-12-2021, 09:49 AM
Looks like traction or clutch/trans is an issue for you?
Car: bmw f20 m135i
Default 05-12-2021, 10:15 AM
the car slips when I accelerate to the bottom
Car: bmw f20 m135i
Default 05-30-2021, 01:56 AM
hi everyone
I have do some run on map 6 just for fun can someone tell me if everything it's ok and help me for the setting
thanks
Default 06-01-2021, 11:06 AM
You're maxing out your turbo...not much more you can get out of it. Timing is a bit wonky, I'd recommend updating your firmware and sticking with one of the standard maps unless you have a particular reason to run map 6 as it looks to me like you have entered unrealistic boost targets.
