(#3301)
mcdale83 mcdale83 is offline
Car: 14 Veloster Turbo
Default 06-14-2020, 09:40 AM
Yes according to the log the engine isn't warm enough to properly lubricate the turbos so the JB4 is defaulting to factory boost. Was that the case or is this an issue with how the JB4 reads water temp on your model?
The temp gauge in the car was in the middle. I waited for the car to warm up.. Is there a setting in the JB4 to help with the water temp readings? I just checked the logs I sent and it isnt getting water temp, trans temp or oil temps.
reyfdiaz reyfdiaz is offline
Car: 2020 Stinger GT1
Default 06-14-2020, 09:46 AM
Not running WMI just E30 mix
Default 06-14-2020, 10:12 AM
Got it must be a bug then, in that case set options bit2 on to disable the warmup safety and we'll need to evaluate why it's not reading water temp accurately.
Default 06-14-2020, 10:14 AM
Ok will do. Let me know if there is anything else you need from me. Thanks for your help Terry!
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default 06-14-2020, 11:11 AM
Originally Posted by sym
Denso plugs after around 20K miles. Originally gapped to 0.022. It's hard to tell from the picture but the electrodes were well worn. Probably going to change them every 12-15K from here on out.
Is this normal? I thought iridium plugs were good for like 100,000 miles?
Iím running map 2 with 93 octane, with about 30k on my densos. Should I replace? Is there any danger if I donít?
atr1 atr1 is offline
Car: Stinger GT
Originally Posted by atr1
Hi Terry
I got a question about map 7.
On what value is the boost additive based on?
I understand that it is a percentage, but a percentage of what value? Is it a fixed value or profile (per gear, rpm) inside JB4 for each platform?
Just in case you missed my question
I am really curious.
Thanks in advance!
Default Limp Mode On Map4 - 06-14-2020, 11:25 AM
Terry can you check this for me. Iím getting a safety 3 fuel pressure on map4 and goes to map0. This has been since I installed the EWG. Prior to this I had the car Dyno and it was running good.
Default 06-14-2020, 12:50 PM
No we suggest replacing plugs every 15-20k miles if you want to be proactive, or when misfire codes start coming up if you're OK being reactive.
Default 06-14-2020, 12:52 PM
Thanks in advance!
There is a high and low map profile that the meth additive and meth flow interpolates between. You'd have to divide these values by 0.70 to convert to actual boost target.
psi_curve[0] = 24 '1500
psi_curve[1] = 28 '2000
psi_curve[2] = 31 '2500
psi_curve[3] = 35 '3000
psi_curve[4] = 35 '3500
psi_curve[5] = 35 '4000
psi_curve[6] = 28 '4500
psi_curve[7] = 21 '5000
psi_curve[8] = 21 '5500
psi_curve[9] = 21 '6000
psi_curve[10] = 21 '6500
psi_curve[11] = 21 '7000
psi_curve2[0] = 24 '1500
psi_curve2[1] = 28 '2000
psi_curve2[2] = 31 '2500
psi_curve2[3] = 35 '3000
psi_curve2[4] = 42 '3500
psi_curve2[5] = 49 '4000
psi_curve2[6] = 54 '4500
psi_curve2[7] = 54 '5000
psi_curve2[8] = 54 '5500
psi_curve2[9] = 49 '6000
psi_curve2[10] = 45 '6500
psi_curve2[11] = 42 '7000
Hockster's Avatar
Hockster Hockster is offline
Car: 2020 Stinger
Default 06-14-2020, 01:55 PM
I just installed my JB4 and looking to update the firmware. I can browse and see the listing of the latest stable and beta file, but attempting to download either one results in a error message stating "firmware download failed. network issue".
Solution to this?
Car: Stinger GT
Default 06-14-2020, 04:13 PM
Thanks! For me that means no short and simple answer. :D
Hockster's Avatar
Car: 2020 Stinger
Default 06-14-2020, 04:42 PM
Solution to this?
A couple hours later the files downloaded fine. Update successful.
rakker rakker is offline
Car: 2019 Kia Stinger GT
Default Log check please - 06-16-2020, 07:42 PM
Running on map3 using the EWG connectors. There have been a few times that it has been acting weird and will go into limp mode where I lose all boost. The second log was one of those times I believe.
Default 06-16-2020, 08:39 PM
If you're triggering an "over boost" limp mode then try setting duty bias to 40 across the board.
Default 06-16-2020, 09:19 PM
Thanks I'll give that a try. How did my logs look otherwise?
Boostd_N Boostd_N is offline
Car: Hyundai Veloster N
Default 06-17-2020, 01:19 PM
anyone with a Veloster N getting a whine noise when in WOT after doing the spark plugs and installing the JB4? I dont get any codes or CEL. Someone told me its normal while others saying it can be a boost leak. Best way to describe it since I can't add a video here is like a supercharger whine.
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 06-19-2020, 02:51 AM
What do the loggs say? Are you getting the desired boost?
2021 kia K5GT.
Iam Broke Iam Broke is offline
Car: 20 Veloster N pp
Default 06-19-2020, 05:50 AM
Yes, map 4, Cai, Def sounds like SC whine here too. I suspect we are hearing the turbo.
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 06-22-2020, 07:03 PM
So after filling today with the usual mixture of E85 and 91, did a pull on Map 3 and it cut off to Map 0. Gave me a Last Safety of 3 for Fuel Pressure Low. Anything I can do to avoid this?
stock_stinger stock_stinger is offline
Car: 2019 STINGER
Default 06-23-2020, 03:49 AM
Might be heavier in ethanol than usual
Default 06-24-2020, 04:32 PM
Just started misfiring on Cyl 2. Time to replace the plugs!!! (Wish I had ordered them a couple of weeks ago)
Default 06-24-2020, 05:48 PM
Log of it? We might be able to lean out AFR to keep pressure up.
Default 06-25-2020, 07:23 AM
Hey Terry, so I disabled bit2 and the car is working great now. Just wondering if the stock ECU will still limit boost until operating temps? I don't want to ruin my turbo by accidentally over boosting before the car is warmed up.
Default 06-25-2020, 08:45 AM
I'm working on that right now, drop me an email and we'll get you some firmware to test shortly. terry@burgertuning.com
sixajd sixajd is offline
Car: 2019 Genesis G70 2.0T
Default 06-27-2020, 07:31 AM
New feature in the works for the Kia JB4 in v15 firmware. See setup directions below.
Note there will be 2 modes. Video shows mode 2.
Mode1:
Choose your map with your wipers on or off, the intermittent speed switch determines the map regardless of wiper status.
Mode2:
Choose your map with wipers on or off, difference is when wipers are actually running, JB4 changes itself to map0 until they are turned off.
Terry I canít get mode 1 to work. I got it working on mode 2 using the screenshot you posted. But when I try and change the 2 to a 1 and save, it changes it back to a 2. I have the most current version of the app on iOS. I got an update for it either yesterday or today actually. Any ideas?
Iím on firmware 17 on the JB4
