(#576)
kerm1t kerm1t is offline
Car: m235i
Default 03-20-2014, 09:58 PM
I hope this is the right place to ask about f22 m235i questions as well. I'm been reading through most of the thread and theres a lot of good stuff.
-When first installing jb4, does it come with the latest software? I have a mac and no pc.
-it seems as the maps have been changed. which map is recommended for a m235i. I just have an intake and a jb4. want to squeeze out most of the power safely. i have heard for m235i, we can run map2 safety because we run high boost stock???
-and just to be sure, does the f30 instructions carry over to the f20? I have a manual and it says i need to splice into a diff set of wires.
-reading this post i saw that manuals can't see what map were on. do i need to always monitor what map i want to be in through a computer and just switch back and forth between 2 maps?
-does in dash boost reading still work?
thanks!
F335 F335 is offline
Car: F30 335i
Default 03-21-2014, 04:47 AM
This is such sad news!!!
What about us with pneumatic solenoids?
20whp is a ****load of power
Surely you can add some of the tweaks for us pneumatic solenoid guys?
Default 03-21-2014, 07:40 AM
Originally Posted by amorak
Terry - Why do you say that "Those with 320 models will definitely want it." Does it allow us to run more boost on our Stage 1's?
On the 320i due to limitations with how the DME set we're still globally limiting boost to around 10psi over stock, which is more than double the stock boost, but the connector allows more boost and better control than without it.
brazil m135's Avatar
brazil m135 brazil m135 is offline
Car: M135i
Default 03-21-2014, 07:48 AM
Any ETA?
2014 Estoril Blue Bmw M135i - 8 AT - N55 EWG - Mods:Jb4 - EWG harness - FF wires, ER Charge Pipe, AfePower Momentum PRO 5R Intake System, H2Racing 3.5" CTless Down Pipe, H2Racing 3" full SS Exhaust w/o mufflers, Wagner FMIC, BMS meth kit 100%, H&R springs, RSV Forged 19" wheels. Now with PURE STG2 and PI
Car: BMW 320i
Default 03-21-2014, 08:07 AM
Terry,
Is this new wg control any better than the previous one?
I mean that one you were able to take control over the 320is wg but ended up no working on N55s.
If any improvement was made, what can we expect to have enhanced over the last dyno run with the old wg control?
What exactly is stopping you from raising the boost to 328 levels?
Is there any way to overcome this issue?
Default 03-21-2014, 08:21 AM
Originally Posted by marcoac14
Terry,
This new approach is working well at least in preliminary testing. We hope to do some 328i electronic solenoid dyno before and after the change soon to quantify the changes there.
On the 320i power is more or less peaked at the 280whp range on E85 due to the higher compression and much higher advance targets programmed in to the DME. It's possible on straight race gas more power can be had on the 320i but we've not tried for it yet.
amorak amorak is offline
Car: F30 320i
Default 03-21-2014, 10:00 AM
Thanks Terry! Will we need the stage 2 for the 320i to take advantage of this, or is this something we can add on to a plain jane (no flex fuel wire) Stage 1?
copperman05 copperman05 is offline
Car: BMW M135i
Default 03-22-2014, 06:13 AM
You will probably need to download the latest firmware update from this site, I also have a mac and use parallels which is essential imo.
You can try map2 but I suspect it will be safer to use the standard map1 if you dont have a DP. Not sure the M235 runs higher boost, its only quoted a few more hp over the M135i and mine saw 330bhp in stock form on the dyno
I dont have a manual so cant comment here.
You can select the map via your laptop (why a PC or Parallels with be essential) and the turn it on or off via the steering wheel. You wont be able to see which map you have chosen but you should feel the difference enough to know.
AFAIK not on the N55
thanks!
jetbill jetbill is offline
Car: E90 335 M Sport
Default 03-22-2014, 07:01 AM
Anyone have any success with using the first and second gear boost limit settings on the F30?
I entered into values 8 PSI First and 10 PSI for second GEAR then I did a couple logs and I noticed it wasn't working, specifically at WOT.
smolik smolik is offline
Default 03-24-2014, 06:45 AM
When setting jb4 to map 0 for dealership, do I need to change the open fuel loop back also?
ghostchili ghostchili is offline
Car: 2014 335xi
Default 03-24-2014, 01:15 PM
Map 0 disables the JB4 so I'd assume you don't have to change it.
DTMBMW DTMBMW is offline
Car: BMW 335i LCI E90
Default 03-24-2014, 01:29 PM
Terry please email me some info. I'm looking to get as close as possible to 400whp on my 335i e90 2011. I currently only have a cobb V3 so please advise me what I need to do and to get to my goal. Thanks again.
Default 03-24-2014, 01:44 PM
The JB4 w/ E85 maps will get you as close as you can get with the OEM turbo.
Chipsy's Avatar
Chipsy Chipsy is offline
Car: M135i Hatch F21
Talking Map2 / M135i F21 - 03-24-2014, 02:08 PM
Hi Terry,
now i have switched from Map1 to Map2 ( without DP ), i have the K+N Airfilter, Wagner Boostcooler and the Performance Exhaust. The Car runs on Map2 very fast, it is a big difference to Map1
Do you think the Map5 there is in Progress, have more Boost as the Map2?
thx + sunny regards from Germany!
Chipsy
Default 03-24-2014, 03:22 PM
Originally Posted by Chipsy
Hi Terry,
Chipsy
The performance will depend greatly on the octane used. On 100 RON you can probably get by with map 2 on an otherwise OEM car. Best to post logs in the support section if you want someone to look over the details for you though.
On releasing an F30 map 5, it's definitely on our radar. We're also working to finalize the F30 electronic solenoid control.
Car: F06 N55 640i Gran Coupe
Default 03-25-2014, 05:47 AM
Hi Terry, can I check with u which map will be the best for me while I have the list of mod here.
Pure turbo Stage
JB4 S2
BMS intake
DP
Supersprint catted bk system
CP
Meth kit
Custom FMIC
Race Gas
Thanks.
Default 03-25-2014, 05:57 AM
3/2013 N55 640i
Pure turbo Stage1
JB4 S2
BMS intake
DP
CP
Meth kit
Custom FMIC
Race Gas
Thanks.
Pls help to shine some light.
13AH3 13AH3 is offline
Car: 2013 active hybrid 3
Default 03-25-2014, 09:16 AM
just installed.....2013 AH3
JB4 next
thanks BMS
Bowser330 Bowser330 is offline
N54TECH FTMFW
Car: E92 335i
Default 03-25-2014, 02:18 PM
I would be interested in seeing a dyno graph from a Jb4 AH3...any interest in getting one done?
Default 03-25-2014, 02:36 PM
sure.....after I get the JB4
do you have a shop that has one? if so where are you located?
N54TECH FTMFW
Car: E92 335i
Default 03-25-2014, 02:43 PM
I think Terry has access to one.
Shamefully, as much as i like seeing the data, I have never gone myself...
...I am just interested in seeing the power and torque differences with the added electrical power.
Default 03-25-2014, 02:45 PM
I'm in FL....bit too far from Terry LOL
I too am curious, will get one done eventually
Default 03-26-2014, 04:34 AM
Hi All N55, can I check what kind of boost level do u get on map7 with JB4 STAGE2?
Don't know why I got only about 12 to 13psi on map7. My car is a 3/2013 N55 F06 640i with all the mod that needed to reach that level.
Thanks in advance for yr input.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
dbBoost dbBoost is offline
Car: 2008 335i Coupe
Default 03-26-2014, 07:53 AM
Sorry if this has been covered already but any ideas on when the extra wastegate control harness will be packaged together with the "off the shelf" JB4 and thus available to the standard consumer? Or is this planned to be something that will always be purchased separately?
2008 335i Coupe 6 speed (sold)
2013 328i M Sport 6 speed
Default 03-26-2014, 08:59 AM
It will always be an add on similar to the FlexFuel connector.
