(#2351)
Default 07-11-2019, 02:06 PM
Originally Posted by P4RTYH4RTY
I recently uninstalled then reinstalled my JB4, and now it feels like there is a lag until 4K rpm. It feels a lot like VTEC; not much going on until after 4K, even at WOT. Iíll usually start my pulls in 2nd gear @ 3k rpm. I donít remember it feeling like this the first time around with the JB4. Did I just forget, or is this normal?
Can you get a log so we can check it out? What map and fuel are you using?
Default 07-11-2019, 07:32 PM
Got in 20 of our unique Stinger zero-service OCC! Get them while they are hot.
https://burgertuning.com/products/bms-stinger-occ
przemek.k przemek.k is offline
Car: Stinger
Default 07-12-2019, 01:02 AM
Sorry if it had been already mentioned but cannot find it.
JB4 / BMS intakes / custom made exhaust 3.3TT - HKS 45iL plugs: should be gapped to 0.22, 0.23 or 0.24?
Which is the best and tested (mostly for MAP1/2)?
robz's Avatar
robz robz is offline
Car: Stinger
Default 07-12-2019, 07:33 AM
0.22 or 0.23 will work.
I'd go with the closer gap to prevent/minimize spark blowout.
Car: Stinger
Default 07-12-2019, 07:48 AM
thanks
RandallK's Avatar
RandallK RandallK is offline
Car: 2018 Kia Stinger GT
Default 07-12-2019, 02:24 PM
Ordered the Catch Can this morning.. super stoked on it...
Default 07-12-2019, 05:02 PM
terrelltechsup terrelltechsup is offline
Car: 2019 Stinger GT1 RWD
Default 07-12-2019, 09:25 PM
Installed JB4 today and ran a couple Map 1 pulls without fuel wires and stock plugs for now. Mind reviewing them Terry? Ill test some more tomorrow now that I have the fuel wires in(damn that little grey positap fitting and the undercarriage covers).
Thanks a bunch.
Default 07-12-2019, 09:48 PM
Thanks a bunch.
Looks all normal to me! Sucks on the posi-tap, we have spares on the site if you need. Or maybe a local hardware store will sell them.
thuglifesk thuglifesk is offline
Car: Kia Stinger GT2
Default New Install - 07-12-2019, 09:51 PM
Hey Terry,
Just installed JB4 in 19 Stinger with fuel wires and denso plugs gapped at .22 as suggested. Please see attached logs for map 1 and map 2 and confirm all is okay. I am current using Shell 91. Usually use Petro 94 but I read in the Canadian thread that Petro 94 is not that great.
Default 07-12-2019, 10:08 PM
Oh don't you worry. I found it. One floor jack, one jack stand, one 10mm socket, 8 bolts and 1 pop rivet later. Thanks again for taking a look at it.
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 07-14-2019, 10:05 AM
I've attached 2 logs; I started each log between 2k and 3k rpm in 2nd gear. I'm running map 3 with e30.
I don't know if this would have any affect, but when I uninstalled the fuel wires the first time around, I noticed a few of the internal wire strands had been pinched off when screwing/unscrewing them in; I ended up just reinstalling them as is. Should I cut the wire down so all internal strands are still intact? Does this make sense?
Thanks.
Default 07-14-2019, 10:14 AM
Originally Posted by thuglifesk
Hey Terry,
I think map2 looks fine here on your Shell 91.
Default 07-14-2019, 10:16 AM
Thanks.
As long as the fuel wires are making contact that is fine. I see boost is limited in 2st gear so that is probably part of what you are feeling. You could try setting that to 0. Other than that I don't see any indications of turbo lag or other issue.
BMS Fanboy
Default 07-14-2019, 10:23 AM
Thank you for taking a look.
Actually, I only have boost reduced in 1st.
Given that it should be getting more boost in 2nd, why do you think it's not?
Default 07-14-2019, 01:48 PM
Set 1st gear to 0 as it goes by road speed currently rather then gear.
BMS Fanboy
Default 07-14-2019, 02:31 PM
Ok, Iíll log again this evening.
Thanks.
Default 07-14-2019, 06:17 PM
Thanks for checking the logs Terry. So should I stick to Shell 91 or try Petro 94 for better readings?
Default 07-14-2019, 06:18 PM
I'd stay with the 91 appears to be working fine to me.
Default 07-14-2019, 07:04 PM
Damn these sold out quick.......when will they be restocked again?
Default 07-14-2019, 07:36 PM
Yes we only made 20 the first batch... We're going to wait for people to install them, make sure everyone is as happy as we expect, then we'll do a larger run. Once we start will take around 2 weeks to complete. So maybe 3-4 weeks out realistically?
Default 07-14-2019, 09:52 PM
I was just thinking of getting the ADD W1 dual catch cans but this seems like a superior product, specially the "no maintenance" part. ill be keeping an eye on this.
ecko04 ecko04 is offline
Car: N55 335i
Default 07-16-2019, 08:23 AM
Terry, for the fuel-it sensor, if I am using the meth FSB where does the wire wire from the fuel-it sensor go to provide that data to the JB4? The blue wire for the FSB is currently in location 16 where the white wire from the fuel-it would normally go.
Default 07-16-2019, 08:48 AM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
ChiTownStinger
