(#401)
Default 07-09-2019, 04:02 AM
Originally Posted by Nora2004
That's the thing it was brought to my attention because the car was jerking, similar to a misfire, luckily I was logging at the time, at that exact time it drops to 60%throttle! Looking now there is a 1psi difference between boost and boost2, apart from that the log looks perfectly normal!
Just popped out there and did 4 logs and they were all spot on, 3rd and 4th gear and a mix of both!
One thing to note is for a day I had to run the car with an open ******** as the wrong Res delete got sent, it was during this driving the car started to feel odd, of course I'm childish and did a few pulls with it like that, could this of affected anything?
Either way it seems to be running as good as always now, hell, even pulled car lengths on an M2 last night!
Sounds like the waste gate was just adapting.
andrew626 andrew626 is offline
Car: golf r
Default 07-10-2019, 04:01 PM
Hi george.
Two weeks ago you wrote that the new maps were going to be aviable.
I don't know why you never posted the new maps and the final firmware.
Please help.
dgraham1284 dgraham1284 is offline
Car: B9 A4
Default 07-10-2019, 09:08 PM
Originally Posted by andrew626
Hi george.
Please help.
+1
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 07-10-2019, 09:51 PM
He post MAP2+ settings which has been tested with several users(Also me) in last 3 months which can be used in MAP6 settings...
Default 07-11-2019, 03:58 AM
We have been testing the new version of software on around 30 cars and all seems to be good. Would be nice to get a bigger pool now.
Firmware version is 60/85//5
Changes are as follows:
Map 3 Peak boost 6psi
Map 4 Peak boost 6psi 7speed DSG specific, it has a taper at higher rpm so will also work well for guys on 93 in hot climates
Map 5 Absolute map peaking 25 tapers to 20psi. E30 with bolt ons needed
Map 8 Safety Valet map
Other improvements are on idle and boost onset.
OBD disconnected yield 0 boost add.
Let me know your thoughts.
JuanFranCupra JuanFranCupra is offline
Car: Seat Leon Cupra 2019
Default 07-11-2019, 08:27 AM
Thanks George
If I have a car with DSG7 ... should I use map 4?
antsh antsh is offline
Car: B9 A4
Default 07-11-2019, 09:37 AM
Thanks as always, George. Map 5 safe for 100 octane (with intake and **), or is E30 needed?
Rrunner Rrunner is offline
Car: Golf
Default Map6 - 07-11-2019, 10:31 AM
George,
Will this new firmware make any difference to a custom map6 running.
Default 07-11-2019, 11:39 AM
Originally Posted by JuanFranCupra
Thanks George
Most 7 Speed cars have got a issue when using launch control. Specifically the R and S3. If you not having issues no need to use it.
It should be ok, read your logs though to be sure.
Originally Posted by Rrunner
George,
Yes, there is improvements on spool up and idle smoothness.
Default 07-11-2019, 02:17 PM
George is test firmware with name JB4_EA888_8_4_T5.hex same as today released firmware JB4_EA888_8_5.hex ? Or is there also some changes between them?
Default 07-11-2019, 03:49 PM
The new maps where not on T5.
Car: B9 A4
Default 07-11-2019, 09:08 PM
Any updates on the code reading issues, George?
Default 07-11-2019, 10:25 PM
Thanks for that info. Does this mean also that T5 firmware in case of issues fail safe will not switch to map 8 but it will switch to old map 4 ?
I will today flash my JB4 with new fw...
Default 07-12-2019, 04:12 AM
It will go to map 8.
Default 07-12-2019, 04:55 AM
Thanks for reply.
I have another questions.
Is stacking JB4 over flash tune still same on latest firmware as has been before? So we use settings from image from 2. post in this thread, select map6 and JB4 will not do anything? Or is selecting map0 better option to avoid any issue for tunner(car will get custom map)?
Thanks again for your time and help.
Default 07-12-2019, 08:10 AM
Thanks for reply.
Same applies for stacking but past few version map 0 is the pass through map with logging ability if you want to log the car with the flash only or stock it the ECU hasn't been flashed.
Obviously Obviously is offline
Car: 2017 Audi S3 Sportback
Default 07-12-2019, 08:59 AM
Hi George,
I’m still using Map 1 and the firmware from 11 December 2018 on my car. Still no hardware done and no issues using LC on DSG7 either up here at the Reef, or at the coast for that matter. I know that you told me that Map 2 is possible without hardware but only with a fuel mix - never tried Map 2 out though. What Map should I use for the most power on 95 pump fuel with this latest firmware and is it true that boost has been hiked up from +4.5 psi to +6 psi now? Do I now use Map 1, Map 2, or Map 4 after downloading this latest firmware, as per some of the previous comments?
Car: golf r
Default 07-12-2019, 09:09 AM
Hi george,
thanks for the new maps!!
For cars with only 91 octane aviable and DSG, which new map can we use 3 or 4?
thanks.
Car: B9 A4
Default 07-12-2019, 12:14 PM
Hi george,
thanks.
I would start with map 1 and post a log, or send it to George. I don't think you'll be able to hold the higher boost up top with 91, especially in warmer weather.
Default 07-12-2019, 01:15 PM
Originally Posted by Obviously
Hi George,
Iím still using Map 1 and the firmware from 11 December 2018 on my car. Still no hardware done and no issues using LC on DSG7 either up here at the Reef, or at the coast for that matter. I know that you told me that Map 2 is possible without hardware but only with a fuel mix - never tried Map 2 out though. What Map should I use for the most power on 95 pump fuel with this latest firmware and is it true that boost has been hiked up from +4.5 psi to +6 psi now? Do I now use Map 1, Map 2, or Map 4 after downloading this latest firmware, as per some of the previous comments?
Map 2 and up is intended for 98Ron or higher. Unfortunately the range with 95 is very limited.
Default 07-12-2019, 01:17 PM
Picked up a issue on some cars with map 5. Attached updated firmware.
Default 07-12-2019, 09:51 PM
Thanks George. Are you targeting more boost in Map 1 with this new firmware as well (+6psi up from +4.5psi, or is Map 1 still exactly the same as in the December update?)
Default 07-13-2019, 05:02 AM
Map 1 is unchanged. 4psi peak add.
Default 07-13-2019, 07:54 AM
Thanks George. You know what - is that DSG7 LC misfire that everyone is talking about, that crackling/popping/misfire of sorts that happens when LC is engaged and only under part throttle? Iíve always thought that it was normal and that it was some form of anti-lag? It goes away if you apply full throttle and hold it against the soft limiter for a short while before launching. Should I be concerned and do I need to get that fix you mentioned for these 7-speed cars some posts back? Use another map perhaps? Iím based up at the Reef and once the car launches, it does so cleanly and without any fuss or drama.
Default 07-13-2019, 08:52 AM
No, the issue is when using LC and just after the gearshift there is a pause, hesitation type and then pull the rest of the gear normal. This happens in all the gears but only when using LC as it shifts to a different map on the ECU.
