(#176)
jrobohm's Avatar
jrobohm jrobohm is offline
Default 93 Pump Fuel - 40/60 H20/Meth juice - BA=80 - 07-06-2019, 09:11 AM
A flat run... man this is pulling hard
Thoughts on this log anyone ?
BMS WMI
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
  • EcuTek Flash (In Work) Seb @ Specialty Z
Default 07-06-2019, 10:41 AM
BMS WMI
Looks pretty healthy to me!
Car: q50
Default 07-06-2019, 10:53 AM
AFR does look better. Only thing I noticed is you're still making some high boost over 5000 (17/18 psi). I'd drop that since you're just pumping heat at that point. Otherwise looks ok to me.
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default Fuel Wires Installed - AFR Reading staying at 25.5 - 07-07-2019, 09:43 AM
Hi Payam & Terry,
While I installed the WMI Kit, I’m hesitant to enable map 8. Reason being, I also installed the fuel wires and now my AFR reading(only for “AFR”, not AFR2) is at 25.5. AFR2 is normal (14.5-ish) at idle. The CEL on intermittently for first time. This only happened after installing the Fuel Wires. I saw a post to enable the future bit D0 and I did. The AFR unchanged at 25.5. Any idea what is causing this?
2018 Q50 Red Sport AWD
BMS JB4 w/Map 0 for WMI Control
BMS WMI Kit
Ecutek Tune by R/T
AMS Red Alpha Cold Air Intakes
Megan Racing LDP
Tanabe Y-Pipe
Mishimoto Heat Exchanger
Car: q50
Default 07-07-2019, 09:45 AM
I would guess you either didn't get the posi-tap on the wire properly or have it on the wrong wire or pinned to the wrong pin of the DB25 connector of the JB4.
Q50Philly's Avatar
Default 07-07-2019, 09:51 AM
Possibly, but I triple checked pin position before installing(measure twice, cut once). I’ll go back and check posi-taps. Thank you!
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Q50Philly's Avatar
Default 07-07-2019, 09:52 AM
Forgot to add CEL on for first time��
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Car: q50
Default 07-07-2019, 09:55 AM
Originally Posted by Q50Philly
Possibly, but I triple checked pin position before installing(measure twice, cut once). Iíll go back and check post-taps. Thank you!
You're doing the white wires on the O2s right?
Q50Philly's Avatar
Default 07-07-2019, 10:07 AM
Correct. I watched the BMS You Tube before installing. Great info there!
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Q50Philly's Avatar
Default 07-07-2019, 10:09 AM
Interesting. After 15 mins of casual driving my CEL went off . But AFR (#1) still at 25.5...under idle and a load? UGH
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Q50Philly's Avatar
Default 07-07-2019, 10:18 AM
Crazy question: any idea which side AFR is?
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
jrobohm's Avatar
Default 07-07-2019, 10:29 AM
Any chance you have a DVOM and can do a continuity check between the posi-tap and the corresponding pin on the JB4 wire harness? If both have continuity it would also be interesting to see if they have @ the same resistance.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
jrobohm's Avatar
Oh and if you turn off FUD Bit 0 - does the same AFT issue occur?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Q50Philly's Avatar
Default 07-07-2019, 11:04 AM
Thanks for the DVOM meter suggestion, I will check. FUD bit0 was originally off and AFR (#1) had the bad reading, which didn’t change when I enabled the setting.
Do you know which side AFR is on (vs AFR2)?
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
jrobohm's Avatar
Default 07-07-2019, 11:19 AM
There is the answer? I believe you need to turn on FUD0 OR the AFR reading will be inaccurate (Terry mentioned this on the v6 firmware notes I believe)
JB4_VR30_OBDII_6:
1) Added support for JB4 fuel control wires. To enable install wires to JB4 and set FutureUseD bit0 on. Once enabled you'll see "fuel enrichment" dynamically adjust in JB4 logs as it drives AFR up to the revised targets. Setting bit0 on WITHOUT the fuel wire will not negatively effect anything, but AFR readings in logs will not be accurate.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Q50Philly's Avatar
Default 07-07-2019, 11:35 AM
Thanks. I will continue to leave FUDbit 0 on. Do you know which side AFR(#1) and AFR2 is located?
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Car: Infiniti Q50 RS400
Default 07-10-2019, 08:45 PM
On your JB4 WMI settings - what are you running with?
Boost Additive = ?
Signal Scaling = ?
Min Flow Boost = ?
External Trigger = ?
Min RPM = ?
Max RPM = ?
ba 40
ss 60
mfb 10
et 1
min default
max default
Default 07-10-2019, 08:58 PM
Hey guys. Anybody else having this weird quirk on the meth gauge on the Jb4 app. When I’m at idle or parked, the meth gauge goes from 1-5. I verified the pump is not on while the gauge jumps up and down. Logs look proper and meth goes 100% at wot. It just started happening about a few weeks go and it’s just annoying. Below is a screenshot and a video link.
IMG_9242.JPG - Google Drive
RPReplay_Final1560219007.MP4 - Google Drive
Default 07-10-2019, 09:10 PM
If all of those fail, just try and remove the positaps and move it up or down 1/4 of an inch. I had a buddy who installed his, almost similar issues than you. He removed it for a couple of weeks until I convinced him to put it back on. No issues since.
Default 07-11-2019, 09:37 AM
Could just be a glitch in the app. Are you on the most updated version of JB4 mobile?
Default 07-11-2019, 09:43 AM
Yes itís the latest from the Apple AppStore.
Car: q50
Default 07-12-2019, 05:08 AM
There's your problem!
Q50Philly's Avatar
Default 07-12-2019, 04:36 PM
Ok folks, WMI is working amazingly well...and I agree with Jrobohm, pulling like crazy! One caveat, I have some tweaking to do, as WMI is running 100% as low as 2200-3000 rpm. I’d prefer a ramp. After shutting down, looks like tubes may have emptied into inlets ( I hope not). Either way....I’m hooked on Meth ;-)
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
Default 07-12-2019, 04:42 PM
Ok folks, WMI is working amazingly well...and I agree with Jrobohm, pulling like crazy! One caveat, I have some tweaking to do, as WMI is running 100% as low as 2200-3000 rpm. Iíd prefer a ramp. After shutting down, looks like tubes may have emptied into inlets ( I hope not). Either way....Iím hooked on Meth ;-)
You can change the min max rpm or change at what psi the meth will start spraying Min Flow Boost. Default is 0, changed mine to 12.
Q50Philly's Avatar
Default 07-12-2019, 04:44 PM
Thanks. I setup at 10, based on Terry’s post to your thread a few weeks ago. I will tweak tomorrow.
BMS WMI Kit
Ecutek Tune by R/T
Megan Racing LDP
Tanabe Y-Pipe
