Hmmm..
Do you have a recent log where it doesn’t drop down to 0 or .8?
I did some research and came up with a timeline, doesn't answer why this started happening however:
3/28/2020 : latest JB4 board installed & connected fuel pressure wires.
4/5/2020 (and prior): was using firmware version 17.
4/6/2020 : no logs so assume still on firmware version 17.
4/7/2020 : upgraded firmware to 18_T1 (for testing).
4/?/2020 : reset adaptations using MHD (may have been the cause of the timing issue, just don't remember exactly when I did this).
4/12/2020 : first time intermittent low/no timing showed up in 3k rpm range.
4/?/2020 : reloaded BEF trying to "fix" intermittent low/no timing issue, made no difference.
4/21/2020 : reloaded firmware version 17 (still have intermittent low/no timing issue).
4/22/2020 : upgraded firmware to 18_T2 (still have intermittent low/no timing issue) .
I also do a 1-4 adaption reset often when testing changes, I might need to stop this and see if the timing issues go away. Prior to 4/12/2020 the timing in the 3k rpm range was mostly great.
