Terix Terix is offline
Car: 2013 BMW 335i
Default Pure Stage 2 Map 6 Settings - 02-15-2020, 08:22 PM
Hey,
I recently got my PS2 turbo installed and am looking for recommendations for map 6 settings to get the most out of it. I posted in the general section and was told that I should post some map 1 logs. I'm attaching a couple map 1 and map 5 logs. They aren't the longest pulls, but hopefully there is enough information. The car definitely pulls hard and is a whole different beast. I just want to make sure I've got my settings right to get the most out of it.
My mods are as follows:
BMS air intake
BMS 7.5" FMIC
VRSF down pips
BMS WMI kit (usually running 100% meth)
N20 TMAP sensor
PS2 turbo (with DV and inlet upgrades)
NGK 2-step colder spark plugs (from BMS)
Default 02-16-2020, 11:56 AM
Hey- id start here, checking out our big turbo tuning sticky.
N55 Large Turbo Tuning Info - N54Tech.com - International Turbo Racing Discussion
Car: 2013 BMW 335i
Default 02-16-2020, 12:11 PM
I looked at that, but the baseline seems to be based around port injection and/or ethanol builds. I'm running 93 octane pump gas.
Default 02-16-2020, 10:59 PM
You’ll likely be octane limited / fuel limited
Your current logs, show multiple timing corrections on multiple cylinders.
What are you looking to do/ what is your goal in mind? We generally don’t recommend users go for “Max” power on just 93
Car: 2013 BMW 335i
Default 02-17-2020, 09:21 AM
I'm just trying to get the most stable settings. I don't need max power per say, just as much as I can get while having the car be stable. If you think I should avoid map 6, then that is fine. Just looking for any recommendations/advice. I've read that having methanol can help with the fuel limitations until I work on moving towards ethanol.
Default 02-17-2020, 07:12 PM
I suggest bumping up slowly, and then you’ll see where the limits are.
Let’s see map 2
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 02-18-2020, 08:15 AM
You might want to think about adjusting your duty bias settings to match the new turbo. If you look at your logs, you'll see that you are only targeting 10 psi near redline. This is a characteristic of the stock turbo, which is what the JB4 is programmed to match out-of-the-box. The PS2 can easily hold much more than that all the way to redline.
Read this: JB4 Duty Bias FF Tuning Info - N54Tech.com - International Turbo Racing Discussion
I have attached a screenshot of my duty bias settings for my PS2.
2011 E92 N55 xDrive 6MT
Car: 2013 BMW 335i
Default 02-29-2020, 04:32 PM
Sorry for the delay in a response. Was having a coolant leak issue that I had to fix. Thanks for the advice fry, I'll look into that.
Dave, I have attached a couple map 2 logs as well.
Default 02-29-2020, 04:56 PM
Logs are a little short, but from data available...
Trims are close to maxing, and getting some timing corrections
Are you using the same fuel?
Car: 2013 BMW 335i
Default 02-29-2020, 05:05 PM
Sorry for the short logs, didn't have time today to get out into the country where I can really push it. Should be able to do that tomorrow.
It's the same fuel. I noticed both with the stock turbo and the PS2 that trims have always been essentially maxing out which I've been confused about.
Default 03-01-2020, 07:02 PM
If we can get some longer logs, that would be most beneficial
Car: 2013 BMW 335i
Default 03-02-2020, 06:41 PM
I was able to get one longer log tonight.
Car: 2013 BMW 335i
Default 03-05-2020, 09:37 PM
Here's another map 2 log.
fryj00's Avatar
Default 03-06-2020, 04:05 PM
It looks like you've entered the duty bias settings but your FutureUseD = 0 (none).
From first post of large turbo tuning thread:
E Series:
1) Run the latest JB4_N55 firmware
2) A JB4 MHD back end flash map is strongly suggested. We provide these maps free of charge as well as tuning support via the n54tech forum, but MHD charges a $199 fee for their flashing tool. Use the PUMP file as a starting point: E Chassis N55 MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
3) Enter the default settings in the second post. Note FutureUseD=64 disables "RPM FF Gain", which allows you to manually enter a duty bias curve that is more appropriate to larger turbos. For pump fuel start with map2, for E85 start with a 40 additive, and log, so we can help you dial it in from there.
Car: 2013 BMW 335i
Default 03-06-2020, 04:40 PM
Unfortunately my DME is locked so I don't have a BEF currently. I've been trying to find a shop locally that can do it. I guess that is step one before I can move forward.
Default 03-08-2020, 11:11 AM
Yes you need the dme unlocked for sure
Car: 2013 BMW 335i
Default 03-10-2020, 10:01 AM
Looks like there are no shops in my area that can unlock the DME, so I've ordered a KTAG device express from China which should arrive within a couple weeks so I can do it myself. I'll post an update once I unlock the DME.
I appreciate the help thus far.
Default 03-10-2020, 05:20 PM
Keep us posted!
Car: 2013 BMW 335i
Default 03-17-2020, 05:34 PM
So I got my order from China today, but they sent the other product the company makes (KESS) instead of the KTAG. However, I just learned that late last year MHD found a way to perform a DME unlock/flash through the ODB port so that a bench flash of the DME isn't required anymore.
I wish I knew this sooner, but last time I tried the app was probably July of last year. I just completed the BEF and am going to take it for a test drive after disabling the FF RPM Gain setting. I will start with some map 2 pulls and try to get some logs.
Default 03-17-2020, 05:47 PM
Double check all settings & FUD
Letís see map 1 or 2
Car: 2013 BMW 335i
Default 03-18-2020, 07:37 PM
Here are some logs. There's a shorter and longer map 2 log, and just as a test with methanol as a fuel additive there are two map 3 logs. I know WGDC and FF are supposed to be close and them seem pretty close, but you know more than I do. I appreciate your help.
Default 03-18-2020, 09:23 PM
Map 3
Trims are near maxing, will need to fix that - bump fol up a bit to 90
We can get you a bit closer to target via duty bias as well
Car: 2013 BMW 335i
Default 03-22-2020, 02:54 PM
New map 3 logs with fol at 90. Looks like the new app update combined the logs (something which I have since disabled), but there are multiple pulls there.
Trims still look pretty bad to me.
Default 03-23-2020, 10:33 PM
Drop down your ethanol mix a bit
Car: 2013 BMW 335i
Default 03-24-2020, 09:11 AM
I'm not running any ethanol. Just 93 octane pump gas + methanol.
