Vipersilver Vipersilver is offline
Car: 2008 e92 335i
Default 30BB DME question - multiple misfires - 10-07-2018, 05:43 PM
The other night on the way home from work the air was cold and I had E30 in the tank, so I did a few pulls.
2008 e92 335i
Mods: JB4 Map 5, DCIs, FMIC, Phx charge pipe s/stock DVS.
I picked up a misfire on 6 that would not clear up. I went ahead and drove home on 5 cylinders since I had read that the computer will shut down the injector in a misfiring cylinder. When I was about 1 mile from home it started to run worse and seemed like a 2nd misfire.
My generic scanner showed misfires on 4,5 & 6, and multiple misfires. I cleared the codes and swapped the plugs and coils in 4-5-6 with known good parts just hoping for an improvement. Unfortunately it still ran just as bad.
JB4 Interface shows 30BB and nothing else. I assume I didn't let it run long enough to pick up the misfire codes.
I pulled the DME and tested the chips, only the mosfet for cyl 5 is bad.
Can a bad mosfet cause phantom issues with other cylinders?
Is there something else in the DME besides the injector mosfets that can cause misfires?
I didn't check compression, but I did put a scope in all the holes and didn't see any piston carnage. (could not see the valves.)
Since I need DME work, is there any reason to upgrade from MSD80 to MSD81?
I see there are places I can send mine in for repair, but I am concerned that there is more than just the bad mosfet 5 in there.
Sorry to load so many questions at once.
Thanks for your help!
Dave @ BMS's Avatar
Dave @ BMS Dave @ BMS is offline
Default 10-07-2018, 08:37 PM
2008 e92 335i
Replace Mofset & i should be ok.
You can upgrade if you want, but in general it’s about a $20-$40 fix, any small appliance shop or PC repair shop can do it for you
Car: 2008 e92 335i
Default 10-08-2018, 08:04 AM
Thanks Dave. I will look for someone local.
The main source of panic was - why are 4 & 6 misfiring if only the chip for 5 is bad.
I will have them all replaced anyway, so hopefully that fixes all.
Dave @ BMS's Avatar
Default 10-08-2018, 10:03 AM
Better safe than sorry- do it once & forget about it
Car: 2008 e92 335i
Default 10-13-2018, 07:48 PM
Update:
I had all 6 mosfets replaced with Mouser part # 844-IRF644SPBF, Vishay N-Chan 250V 14 Amp.
A local electronics repair shop charged $140.00 to do the soldering - a little higher than what others have paid but I was happy to pay it.
#6 coil was toast. I dropped in a spare coil and it runs great now.
So the answer to the question "can 1 bad injector mosfet cause misfires on the whole bank?" - yes.
Thanks for your help.
Dave @ BMS's Avatar
Default 10-14-2018, 07:39 PM
Update:
Glad you are back on the road!
