andrews013's Avatar
andrews013 andrews013 is online now
Car: 2013 E92 335i xDrive
Default E85 BEF Big Stutter - 12-02-2019, 11:26 AM
Today when doing my first logs with the e85 BEF and map 2, I hit a major stutter. To me, it looks like the HPFP crashed, possibly due to slight overboosting. Do I need to revisit DB tuning, is the HPFP at its limit, or is there something else I can do to fix this?
Default 12-02-2019, 01:14 PM
Fuel pressure is the weak link on these. Boost and tuning look OK.
What E85 mix?
andrews013's Avatar
Default 12-02-2019, 01:23 PM
Here's the gas station:
Store Details - Kwik Trip | Kwik Star
They indicate 75% E E85 and 10% E 93. I did a mix of 7.5 gal E85 and 8.6 gal 93 = E40ish. Maybe it's time to start testing at the pump.
2013 E92 335i XDrive
JB4, MHD E85 BEF, XHP, XDelete Sport, VRSF 7 HD IC, GFB DV+, VRSF CP, VRSF D/P, PE Mod, ST V1 Suspension.
Default 12-02-2019, 01:34 PM
Try lowering the mix to see how low you need to go to get fuel pressure to maintain.
andrews013's Avatar
Default 12-02-2019, 01:51 PM
Ok, I'll put a gallon of 93 in and see how it does. Thanks!
Default 12-02-2019, 06:59 PM
Id add 2 gallons
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
andrews013's Avatar
Default 12-02-2019, 08:06 PM
Id add 2 gallons
Will do, thanks. Is this due to my stock lpfp, or is the hpfp already maxed out?
andrews013's Avatar
Default 12-03-2019, 12:24 PM
I added two gallons of 93. The HPFP is still crashing at low RPM. I have attached one log where the hpfp barely holds on, and one where it completely crashes. What should FOL be set to when using a BEF?
Default 12-03-2019, 02:40 PM
FOL has no effect on fuel pressure.
Fuel pressure is improved here. Could lower the mix a bit more or lean out the AFR to keep it up if it gets to the point that it's sputtering like this.
andrews013's Avatar
Default 12-03-2019, 02:43 PM
Ok, I'll put in some more 93. It still sputters out if I start a pull below 3000 RPMs. Too bad it can't handle more e85... I was hoping to run more timing.
andrews013's Avatar
Default 12-06-2019, 08:26 AM
I added two more gallons of 93 (total of four additional) and I am still crashing the HPFP. I noticed slight overboosting in the logs... Would bumping down duty bias below 4000 RPM help? Or just more 93?
Default 12-06-2019, 09:13 AM
Boost targeting is fine here.
On fuel pressure I can't tell why it's crashing as you should be able to hold on a mild E85 mix. Your options are to lower boost, check low fuel pressure by adding a sensor or gauge to confirm it's OK, or maybe swap out the high pressure pump.
andrews013's Avatar
Default 12-06-2019, 09:44 AM
I just read about how the hpfp was changed for late E series cars and flows less... Could that be what I'm seeing?
andrews013's Avatar
Default 12-06-2019, 03:38 PM
Another two gallons of 93, another log. No sputter, but rail pressure dips a lot.
Default 12-06-2019, 05:46 PM
And now timing is taking a hit. I suggest less boost until you can sort out why the pressure isn't holding as well as other cars.
andrews013's Avatar
Default Today, 01:55 PM
I filled the rest of my tank with 93 and switched to the pump BEF. How does this log look, besides my turbo falling on its face?
