Sideways the Seven Sideways the Seven is offline
Car: 2016 Q50 3.0t Premium
Default 2016 Q50 3.0t Prem on 93 octane and Map 6 - 12-02-2019, 01:54 PM
Hello guys, new member here.
Looking for some feedback on my logs. Been looking for ideal settings for my application. I've been running 93 octane but have easy access to E85, if I need that as well. I appreciate any help or direction you guys can give. Thanks!
Lonmon Lonmon is offline
Car: 16 Infiniti Q50 3.0t AWD
Default 12-02-2019, 02:20 PM
I can't use this log. There is way too much and I can't find a decent pull quickly. You need to go out and find a good flat stretch of road, start in second gear around 2500 rpms, start the log then go full throttle till the car gets well into 4th gear (SAFELY!!). Then let us look at the log. You can do this a couple of times if you like just to make sure to get some good data. The partial throttle info just makes it difficult to find what we need to see, especially when the log is very long. Most logs only need to be 30 seconds or less. At this level of modification the partial throttle information is not too important unless we are trying to diagnose a specific issue. I would not go beyond +6 in your map until we verify that everything looks good, especially when only on 93.
2016 Q50 Premium 3.0t AWD
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
Default 12-02-2019, 02:24 PM
Look at the map from Serstylz2 on page 197 of the top topic. Use this map but replace the 7's with 6's until we look at the logs. Then if everything looks good you can insert the +7's and let us look at the logs again.
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
Default 12-02-2019, 02:31 PM
Originally Posted by Lonmon
I can't use this log...
Will do. Thanks for the quick reply!
2016 Q50 3.0t
*HKS BOV
*Infiniti Sport exhaust
*JB4
Default 12-03-2019, 10:47 AM
Updated. Here are the new logs. Thank you!
2016 Q50 3.0t
*HKS BOV
*JB4
Default 12-03-2019, 01:34 PM
Keep in mind tuning is disabled until engine is warmed up. The warmed up log looks OK to me though at first glance.
Default 12-03-2019, 01:43 PM
Ah, good to know, thank you!
I'm still learning about this platform. I appreciate the feedback!
2016 Q50 3.0t
*HKS BOV
*JB4
Default 12-05-2019, 08:33 AM
Found a nice clear road to get a really good pull last night. How do these look? If I'm reading this correctly, everything looks okay.
2016 Q50 3.0t
*HKS BOV
*JB4
