AndyG AndyG is offline
Car: '07 E92 335i
Default 8 bolt to 6 bolt longblock swap question - 03-06-2017, 12:13 PM
I have a 2010 335i that needs a motor. The previous owner hurt it somehow, I bought it with a hurt rod bearing. My 2010 apparently has an 8 bolt crankshaft, can I use an earlier 6 bolt crank motor or is that more trouble than it's worth? The reason I ask is because I am having a harder time finding an 8 bolt crank motor. The earlier N54's seem to be much more prevalent. Thanks guys!
I have not had time to pull the motor out yet because of other car projects I've had going on so I me have the 8 bolt and 6 bolt thing backwards. It is not easy to find information like this online unfortunately.
2007 E90 335i, single turbo, daily driver
2007 E92 335i, FBO Jb4 - Sold
1999 C5 Corvette single turbo 5.3
Alex@abrhouston Alex@abrhouston is offline
Car: m3
Default 03-06-2017, 02:06 PM
swap the flywheel/flex plate. that's it.
abrhouston.com
832-797-9114
Car: '07 E92 335i
Default 03-06-2017, 06:26 PM
Thanks Alex, that's what I needed to know.
Bmstation Bmstation is offline
Car: E87 120I N54
Default 03-11-2017, 06:51 AM
01/2009--> have six bolts
mixhali mixhali is offline
Car: 2009 335
Default Doing same - 06-24-2018, 07:24 PM
Hi AndyG, Did you go ahead with this. Any issues? what exactly did you swap. Doing same myself.
09 e92 335 AT - MHD Flash, RB's, TFT intake w/Tial BOV, Fuel It Stage 2 pump, Wagner EVO 2 FMIC. VRSF DP's, JB4 + Mobile
Default 06-25-2018, 07:43 AM
Flywheel or flexplate is the only thing that will need to be swapped.
1985gsl 1985gsl is offline
Car: 07 335i
Default 07-27-2018, 01:33 PM
Correct you will only need to swap flywheel, it only gets complicated when you have a twin disc clutch. Also you have the 6 bolt vs 8 backwards, early motors are 8 bolt, later are 6 bolt. Your car should have a 6 bolt.
