Originally Posted by blown07
It is possible to install the center support bearing upside down (not sure if he disconnected this or not). When I took the shaft out of mine to do the diff I also marked the flex connection on the trans to make sure there was no vibration.
I've done most of my driveline work on trucks so I'm not totally familiar w/ the e90/92 driveline because I haven't messed w/ it, but it sounds like it is out of phase. google "driveline phasing" & you'll see all the different types of drivelines & how they should be.
for example:
