ferocious's Avatar
ferocious ferocious is offline
Car: 335i N54 2008
Default Single turbo Over boost - 09-15-2017, 04:17 PM
Hi guys,
Im having realy bad over boost on all maps except map1
It seems that i keep trying to set Bias settings all to 50
But in the log it shows up as 0?? And i get over boost
Map1 is fine tho
Things i tried that didnt work:
Re updated Jb4 ST HEX
Reflashed MHD ST TS
Rechecked wastegate fittings and bolts tightened
Rechecked solonoid vacuum hoses
Rechecked all vacuum T fittings
Rechecked hose diagram and was correct
Id really apreciate your help
Joe
2008 335i N54 FFtech Top Mount single turbo Precision 5862
JB4 G5 , VRSF 7" FMIC , VRSF CP + HKS BOV, Tial Wastegates
BMS METH KIT IN CONJUNCTION WITH MMP PI WITH 1055CC INJECTORS, PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. CUSTOM TUNE, xHP Stage2 v1.5
more to come...
Default 09-15-2017, 04:21 PM
Map1 seems OK, although the WG spring seems really tight. Then on map8 WGDC goes up slightly and boost goes out of control. Maybe solenoid plumbed in backwards?
ferocious's Avatar
Car: 335i N54 2008
Default 09-15-2017, 04:29 PM
Ok terry
Thanks for replying
I will switch the hoses on the mac and do a run now
And post another log on map 8
more to come...
Default 09-15-2017, 04:34 PM
Just look at it carefully and evaluate. Solenoid output has numbers, etc.
ferocious's Avatar
Car: 335i N54 2008
Default 09-15-2017, 05:47 PM
Ok terry
This was the outcome
Seems to be solved thanks to you
But i think it needs a few WOT's to adapt more
by looking at the log attached and its settings
Is there anything that needs to be adjusted?
Thanks Terry
more to come...
Default 09-15-2017, 08:51 PM
Looks solid to me! Now it's just a matter of figuring out how much you want to push the setup.
07335i's Avatar
07335i 07335i is offline
Default 08-05-2018, 12:37 PM
it was solenoid plumbed backwards???
