(#1751)
chilam1019 chilam1019 is offline
Car: 2009 E60 535i
Default 03-14-2011, 12:12 PM
Great will wait for that Idrive radio off.
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 03-14-2011, 12:22 PM
Exhaust Flapper FTW! You will make a lot of people giddy with that one T!
Mods: FBO
GbreeE90 GbreeE90 is offline
Default 03-14-2011, 02:38 PM
Terry I have a quick question about JB4 and fueling. If I understand correctly, the JB4 lets the stock DME adjust fueling. Obviously however it is set up works fine, but does the MAP sensor have a maximum anticipated pressure? I know in a lot of other vehicles with MAF sensors they have to upgrade the MAF sensor when running increased boost because it has a maximum anticipated airflow which causes static flow. I am just wondering how you achieve correct AFR.
Default 03-14-2011, 03:06 PM
Not quite following you. But the N54 uses wideband o2 sensors so always targets the programmed air/fuel ratio. We alter that ratio but the DME does the targeting.
Default 03-14-2011, 03:10 PM
Okay, I was just confused. I know DME uses the O2 sensors but I thought it used multiple inputs to target the correct AFR. Thanks for clearing that up for me.
Blue Streak Blue Streak is offline
JB since 2007
Car: 2007 335i
Default Map 5 / 2 - 03-14-2011, 09:07 PM
I've been on map 5 exclusively for about 3 or 4 weeks now and have been very happy with it. I'm using Shell CA 91 with a mix of about 4 gal of Sunoco GT260 100 oct race gas. (intake/3"DP). But I switched back to map 2 tonight and there seemed to be much more power and stronger at lower rpm. I really haven't had a chance to do any strong pulls in map 5 in 3rd/4th gear in several weeks, so I just wanted to go back to map 2 and hit it hard on the freeway for a bit. It was great, but I'll probably keep it on map 5 most of the time and switch to map 2 on the fly once in a while when I want to hit it hard. That is as long as I've got some race gas in the tank.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 03-14-2011, 09:09 PM
+1 i switched to map2 last night just for kicks, but it def felt like it had more punched compared to map 5.
2014 F10 535i N55 PWG
JB since 2007
Car: 2007 335i
Default 03-14-2011, 09:16 PM
I think I'll have time his weekend to take a long freeway drive with my laptop to do some data logging. I'll try several pulls with each map and the same blend of gas and see what's going on (and ask T's opinion of course). I want to stay safe, but maximize performance within reasonable parameters. If it looks worth while, I'll share on this thread or maybe let T decide if he want's to post it here after I e-mail the files to him.
Dirty Dog's Avatar
Default 03-14-2011, 09:17 PM
Map 2 definitely stronger for me too but map 5 is the brains.
135i - JB4 15ohm l Mr 5 Intake l AA C@tless ********* l ETS Intercooler l BMS Methanol Injection l Berk Tech Mids l Berk Tech Axleback l BMS OCC l ER CP l Turbosmart BOV's. SOLD
335i DCT - JB4 G5 ISO l AA C@tless ********* l ETS Intercooler l Custom Intake l Meth l BMS E85 Flash l BMS OCC l ER CP l Walbro 255 l Turbosmart BOV's. CURRENT
JB since 2007
Car: 2007 335i
Default 03-14-2011, 09:35 PM
Yes, I agree. It's smoother and has a more deliberate surge in power that uses the whole RPM range, more like a N/A V8 than anything. (map 5). I enjoy both maps a lot, just depending on what I want at the time. Thank T for the on the fly map switching!
twinscrewcaddy twinscrewcaddy is offline
Car: Blk '07 335i e92, 6MT, iForged 19's
Default 03-14-2011, 09:40 PM
what would be an equal or better JB4 map compared to JB3 Map 7 on 93oct and DCI'ed car?
thinking of doing the upgrade... i also have DO meth kit to add soon.
Bash Bash is offline
Car: E92- 335i
Default 03-15-2011, 02:18 AM
What is the exhaust flapper? What does it do and will it give more power or something? Excuse my ignorance on the subject.
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 03-15-2011, 09:11 AM
Someone please correct me if I'm wrong, but it's my understanding that the 'exhaust flapper' opens when vacuum pressure is high enough, such as during heavy engine load/wide open throttle. This allows it to remain closed and quiet the exhaust while cruising around town and rids the 'drone' some may experience on the highway. Having it closed also provides additional back-pressure which some suggests increases low-end torque response. However, under heavy engine load/WOT it opens up to reduce back-pressure and provide a more open exhaust, resulting in a louder exhaust and more power.
Regardless of the science behind it, most unplug it because they like the way the exhaust sounds (like me ), almost as if you have an aftermarket exhaust.
mikeyt13 mikeyt13 is offline
Default 03-15-2011, 09:21 AM
HOw do you unplug it?
Car: '07 SGM 335i
Default 03-15-2011, 09:26 AM
There is a vacuum actuator near the driver's side muffler with a black vacuum line running to it. Most unplug it and plug the vacuum line with a golf tee, thus why it's sometimes referred to as the 'golf tee mod.' The proper way to do it would be to also cap the actuator as well.
Back on topic - I took the time to throw down some solid 3rd/4th gear runs in Map 5 and I must say it now feels STRONGER than Map 2. I am in the process of compiling my datalogs and will post results once completed.
Default 03-15-2011, 09:28 AM
Thank you
dirtyballoonot dirtyballoonot is offline
Car: 2007 335i Sedan AT
Default New Install - 03-15-2011, 10:49 AM
My buddy is installing while I'm at work. He's being a bit overly cautious and claiming that I shouldn't "get on it" as soon as he's done. It was my understanding that it needed to be "opened up" to adjust. The instructions say "drive as you normally would", well, I drive like a maniac most of the time, so, what's the verdict?
alpinedevil335's Avatar
alpinedevil335 alpinedevil335 is offline
Car: 09' 335i Sedan
Default 03-15-2011, 10:55 AM
You'll need to do a few WOT pulls for it to adapt. So your driving like a maniac style is perfect. Just please be carefull.
Default 03-15-2011, 11:35 AM
Careful, funny
Larry Larry is offline
Car: 335 XI Coupe
Default 03-15-2011, 01:18 PM
I have the JB4 on order. When I get it can I update the firmware w/o it being installed in my car (someone else is installing it)?
Default 03-15-2011, 01:22 PM
It will ship with the latest. But has to be installed to update firmware. Have them install the USB cable and route it under the ECU cover so its accessible in the engine bay.
Car: '07 SGM 335i
Default Map 2 vs Map 5 - 03-15-2011, 01:53 PM
Like many others, I was curious whether I was missing out on some extra power by switching to Map 5, so I finally took an opportunity to log some 3rd and 4th gear pulls this weekend to compare the two maps. The results may surprise you, I know they did me!
Car: 2007 335i Steptronic
Mods: JB4 and BMS DCI (all else stock)
Fuel: 93oct
Air Temp: 40F
Map 2
Although boost peaked as high as 15psi, it seemed to taper from 14psi down to 13psi.
Map 5
What you can identify in these graphs is the system "learning." The first run starts out quite conservative (as it should), between 11-13psi. Run 2 was much smoother at 12-13psi. Finally, run 3 pulled HARD, starting from 15psi with a nice taper down to 13psi. I also notice that Map 5 pulls much harder than map 2 while driving around town, more low and mid-range torque in lower gears. Map 5 FTW!
VictorFranko VictorFranko is offline
Default 03-15-2011, 03:50 PM
That would be the equivalent of somewhere between Map2 and Map7 on the JB4.
All of which would be over aggressive for just a DCI and pump gas.
Default 03-15-2011, 05:11 PM
Ok...so, first impressions there's definitely more power...map 5 seems more like stock than 1 or 2...definate traction issues...I'll likely have to limit the boost on 1 and 2...
Odd issue though...in map 2 I hit the limiter and it engaged limp mode and got a CEL after bogging down...I've hit the limiter in the past with no issues...
prelude2perfect's Avatar
Car: '07 335i
Default 03-15-2011, 07:54 PM
Have you done some WOT runs in 3rd and 4th gear in map 5 to let it adjust? It definitely shouldn't feel like stock once it hones itself in.
Why are you hitting the limiter on this car anyway? The stock turbos are so small that you're only hurting your car by going that far up the tach. You make more power underneath the redline so it makes more sense to shift before you even go into the red.
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
