(#1476)
DeadEye's Avatar
DeadEye DeadEye is offline
Default 02-23-2011, 05:09 AM
Originally Posted by E90PAT
thats no joke! when i first istalled the jb i took her out for a spin and wasnt impressed, then driving home from school on the highway i overtake a truck DAMN! where did all this power come from??
Cold oil protection, JB4 runs at stock boost until the oil warms up.
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 02-23-2011, 05:12 AM
Originally Posted by Kongen71
it's out - check the first page
nop...
2/21 it´s out
2/22 where???
salu2
Time is the best teacher
Too bad it kills all its pupils ....
Lorto Lorto is offline
Car: 2007 335xi
Default 02-23-2011, 05:16 AM
I'm sure he meant his LOGS were from 2/22 (since that was the date he made the post).
Kongen71's Avatar
Kongen71 Kongen71 is offline
Default 02-23-2011, 08:25 AM
+1 tune wont engage before oil is 160F. Nice safety
kang159 kang159 is offline
Car: 2010 335i Coupe
Default 02-23-2011, 01:11 PM
Anyone else have an issue with your boost gauges not reading the same boost as the boost on fuel? My vent gauge and JB4 don't read the same @ low boost but they do seem to be showing similar peaks. When my vent gauge is showing 0 psi, the JB4 shows about 4 psi. Is something wrong with my vent gauge?
E S P E S P is offline
Car: 335i convertible, JB4, Injen intake
Default 02-23-2011, 01:15 PM
Thanks Kongen. Will set it up today.
So pumped for auto tune.
Running V power. Sounds like your in Sydney?
I live in Manly. U?
Have done intake and would like a bit more sound. Thinking muffler delete soon but worried it's too loud?
DeadEye's Avatar
Default 02-23-2011, 01:16 PM
I've no reason to think the JB4 is wrong, at very slight throttle the boost gauge moves to 2psi etc.
I did have to do a "reset the dials in case they get confused" on mine a few firmware revisions ago as it was boosting to well over 12-13psi when it was cold and 20+ when warm.
Kongen71's Avatar
Default 02-23-2011, 02:44 PM
I live in Manly. U?
Do the DP's. More sound and more power. Btw I couldn't be further away from Sydney - I'm in Europe V Power is from Shell which is Dutch
Default 02-23-2011, 02:46 PM
Pre-boost vs. manifold boost.
GtiGyver GtiGyver is offline
Default 02-23-2011, 02:50 PM
I can't seem to get the calibration right for the gauge interface on my metric 135i cluster.
The tach is right-on, but the speedo is way off. I tried all the different cluster combinations in the JB4 settings but nothing makes sense.
Any suggestions?
OldBooster's Avatar
Car: 2008 135i AT
Default 02-23-2011, 02:56 PM
CMGS gauge (and other gauges) shows manifold boost, and methanol/alky/H2O injects based on manifold boost levels, thus the vacuum tube.
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Default 02-23-2011, 03:08 PM
Any suggestions?
Another 135i metric guy mentioned we may have a bug there. Send photos of it in 135i metric mode, at what should be position 1, 2, 3, and 4, and we'll recalibrate an option for you.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 02-23-2011, 04:12 PM
So I just updated to the newest firmware 2/21.... Should I put "future use D" to 0 now instead of 2 since autopid is automatically set??
2014 F10 535i N55 PWG
Default 02-23-2011, 04:15 PM
You can. Doesn't matter though.
E90PAT E90PAT is offline
Car: 08 BMW 335i
Send a message via AIM to E90PAT
Default 02-23-2011, 08:10 PM
i read my codes and got a 2aaf fuel pump code and another (on my netbook in my car right now) fuel pump related code, should i be worried?
GbreeE90 GbreeE90 is offline
Default 02-23-2011, 08:15 PM
I have the same code (2aaf), Terry informed me that its a common tuning code. No worries
Dirty Dog's Avatar
Default 02-23-2011, 08:35 PM
I live in Manly. U?
Hi ESP,
I just sent you a PM.
I work in Manly.
Naptime's Avatar
Naptime Naptime is offline
Asleep at the wheel
Car: 2007 335i Sedan
Default 02-23-2011, 08:59 PM
Originally Posted by elsabor67
I Like Maps 1&2 with their aggresiveness and the power on tap, but I am really starting to like map 5. Very progressive and adaptable. I was mapswitching on the way to work this morning and you can definetly tell the difference.
Now to update and do some logs today!!!!
I'm quickly becoming a huge fan of map 5.
I plan on making it to the dyno after I install my Raceland's to get a baseline on power. I am really curious about what kind of power an N54 with a JB4, DCI and *** on 93 oct and Map 5 will make.
I'm guessing about 350 rwhp...
2007 E90
Not Fast, Not Slow.
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 02-23-2011, 09:02 PM
I have code 29F2. It is going in on Friday for HPFP. Should I leave that code in or clear it?
Mods: FBO
Naptime's Avatar
Asleep at the wheel
Default 02-23-2011, 09:14 PM
I'd leave the code in.
Clearing the code may lead the service tech to wonder how the ECU isn't throwing a code related to HPFP failure. With some of the threads I've seen on this board and others, I wouldn't give the dealership any rhyme or reason to void my warranty on any level.
Just my $0.02
2007 E90
Not Fast, Not Slow.
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 02-23-2011, 10:01 PM
am also curious to c this dybo ,but i guess it should be MORE than 350 RWHP ,maybe close to 400
Default 02-23-2011, 10:32 PM
Only if you expect the dealer to fix it.
Bimmer Barney's Avatar
Bimmer Barney Bimmer Barney is offline
Car: 07 E90 335i
Default 02-24-2011, 12:11 AM
Just emailed you some logs, Terry!
m1bjr m1bjr is offline
Car: 335i E92
Default 02-24-2011, 06:20 AM
Map5 - is the autotune data fully retained by the JB4 when switching out to another map, and then back to 5?
TIA
Steve
Country Roads!
Car: 2009 135i
Default 02-24-2011, 06:31 AM
Ha ha! Thanks! I wasn't exactly sure what the code was for. When these pumps go, they really go. Flatbed pickup tomorrow!
Mods: FBO
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
